14th July 2013, 12:13 AM
Gq mechanical fuel pump
Can anyone explain which hose goes where or is the a diagram showing fuel flow?
14th July 2013 12:13 AM
14th July 2013, 02:14 AM
There should be an arrow on the pump itself showing flow directions one pipe comes from the tank and then the other leads to fuelfilter and carby
Guns don't kill people, people with mustachios kill people
14th July 2013, 10:55 AM
The large diameter I think must be feed from tank, there are 2 others 1 must be to filter and carby and the other a return to tank it's which way round these 2 go?
14th July 2013, 04:46 PM
I really don't think it would matter as if its returning it to the tank it would be the same flow I would suggest get someone the crank the car over and see which one pumps out then that's the one to the carby
15th July 2013, 10:04 PM
Hi,
From my experience, there isn't a return on carby motor?
Bottom pipe is to filter/carb, top one is from tank (both same size) and third one should be easy
Evo
Cheers,
Evo
18th July 2013, 02:34 PM
There is s return on mine. Its before the carby though. Theres a valve bolted to my intake manifold. A certain pressure goes up to the carby. The rest is sent back to the tank.
Theres three lines. Feed to filter and carby, return line to the tank and the third is a vapour line.
Dont know which is which though
Sent from my GT-I9305T using Motorculture mobile app
'92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
Lukey 2.5" Performance Exhaust with Extractors, snorkel
Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
12th September 2015, 06:47 AM
I have in mine (TB42 carby 92) three fuel lines on pump,
1. supply line from tank
2. pressure line to carb
3. return line to tank
