9th July 2013, 09:56 AM
The TSL Super Swamper is an aggressive tyre but use hearing protection when on the bitumen.
9th July 2013 09:56 AM
9th July 2013, 11:12 AM
CERTIFIABLY INSANE
td42dan
so what a/t tyres is everyone running????
im running maxxis bighorns atm, 33x12x15, thinking about changing to an a/t tyre....
so many choices out there!!!!!!
What terrain mix are you going to be driving? What is the vehicle being used for? They are the first things you need to understand before making any decisions.
As you probably know, there are AT tyres to suit more blacktop use all the way through to those that work ok (note I only said ok) in mud.
Understand what you'll be using the vehicle for and we'll probably be able to narrow your choices a bit better.....
Cheers,
Drew.
Tip tip tip......tap tap tap....
9th July 2013, 12:59 PM
Has anyone tried the Yokohama Geolander ATS?
http://yokohama1-px.rtrk.com.au/en/T...andar-ATS.aspx
The guy from the tyre shop highly recommended these as they performed well in the 4WD action comparison a while back, and they come with a replacement warranty protecting against damage (including sidewall). I just couldn't go past the BFG A/T's though, I've had them before and they were faultless.
GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
KEEP OUR TRACKS LITTER FREE!
9th July 2013, 08:14 PM
BearGUST
Wow, $90 extra a rim to go from a 265 to a 285.... That's a fair chunk of cash right there.....
