Results 1 to 10 of 10
Thread: wire rope preventative maintenance.
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    G,day, all. I have tried the search function, but haven't struck pay dirt on the subject. Is it advisable to use water repellent sprays, such as CRC, or wd40, on the cable? Or does it rot out the wire.
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    1999 GU 4500 dual fuel
    Il dado è tratto
  4. The Following User Says Thank You to NP99 For This Useful Post:
    mudnut (6th July 2013)
  5. #3
    SW Vic.
    80 Post(s)
    Ok, what do most of you blokes use?
  6. #4
    brisbane
    Best way is to remove it from the winch put on some rope then place the wire in the back shed so it won't get kinked/frayed
  7. #5
    SW Vic.
    80 Post(s)
    Yeah, yeah, I know, I'm sold on dyneema, but that and the sheath to stop the brake melting it is way down the list of mods needed. So I'm stuck with the wire for the moment.
  8. #6
    I would think in the old days , guys would clean with a brush and some diesel. Pat dry then spray CRC or Lanotec to prevent rust.
    You also don't want to attract dirt, your local sling/shackle shop may sell SWR cleaner, as MT suggests remove it, Dyneema is now
    $179 free post for 40mtrs of 10mm. Less weight on front end has to be good.
  9. The Following User Says Thank You to threedogs For This Useful Post:
    mudnut (7th July 2013)
  10. #7
    Patrol Guru
    Apr 2011
    Melton
    The most important maintenance for wire rope is to ensue that once you have used it - you run it and put it back onto the winch correctly layered with no cross overs. If you winch and the rope is laying on a vcross over it can kink the rope.
    I spray my wire ropr with onox once in a while
    1991 GQ LWB 4.2 Carby dual fuel, 32 mud claws, 2 inch lift, LSD's front and back
    And its Toooooooo High for the Ball & chain
  11. The Following User Says Thank You to GQ TANK For This Useful Post:
  12. #8
    Plus always wear leather glove when ever handling SWR,
    be very wary of broken wires they do hurt.
    Kinks are a weak point if not too far from end have new hook or eyelet swaged on,
    throwing damaged part away. Respool under tension With the last 10 ft or so quickly
    criss crossed over tightly spooled SWR, Be careful respooling with gloves too as winch
    will grab gloves and feed your fingers in, stand back 4ft to give yourself some room
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #9
    Apr 2013
    there is proper ligued type grease that sticks for SWR..but it makes for a messy affair if you have to handle it
    Rocol
  15. #10
    Expert First Patrol's Avatar
    Sep 2013
    Gladstone, QLD
    We use a wire rope lubricant on our cranes which does not attract dust lubricates etc. if it's recommended on crane winches i would use it on my 4x4 winch I'll get brand name soon mate
    Stand by
  16. The Following User Says Thank You to First Patrol For This Useful Post:
    MudRunnerTD (2nd October 2013)
