Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: my tray build.
    22 Post(s)
    my tray build.
    Gday.
    I am starting to get some steel together for my tray build.
    My head stock and brace arrived today, I got that bent up by bendpro in Maryborough, its 3nch, 3.2mm wall seamless pipe all mandrel bent.
    The 2 chassis rails are 2 inch pipe, 3mm wall and the bends are for the wheel arches. All I need to get bent up now is the outer rails.
    The tray is going to be 1.8m wide, 2m long. The outer rails arnt going to match the inner rails. The are going to taper out to about 1.9 over the rear wheel and taper back in to the rear of the tray. The wheel arches them selves are just going to made out of steel plate.
    96 GQ coil/Cab
    08 G6eT
    Feb 2011
    Shed
    45 Post(s)
    Bout bloody time I've been waiting for such a thread
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Will be watching. Have fun with it..
    Owner of
    Westy's Accessories
    Very shmexy.......
  6. #5
    Should look good are you welding steel checker plate or popping polished alloy checker plate on.
    So many questions ATM
  7. #6
    22 Post(s)
    All steel mate.
    96 GQ coil/Cab
    08 G6eT
  8. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    threedogs (28th June 2013)
  9. #7
    North brissy
    Galvanised once done??
  10. #8
    recessed space cases??
  11. #9
    22 Post(s)
    Havnt planned that yet I want to move the batteries to the back and install the air compressor and tank.
    If I can find some space cases the right size I will throw some in
    96 GQ coil/Cab
    08 G6eT
  12. #10
    581 Post(s)
    Awesome benny, keep the thread up to date mate, interesting to see it unfold!
