Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: my tray build.
    22 Post(s)
    Galvanised once done??
    I think so
    96 GQ coil/Cab
    08 G6eT
  2. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    macca86 (8th August 2013)
    22 Post(s)
    I picked up the sides of the tray the other day. I have to go back to work for another week. But when I get back get the rest of the steel and start building!
    Here is a mock up of the headstock, main rails and side rails, the main rails used to be the side rails they were already bent up when I got some advice on tray design, so intread of turfing them I just moved them to the middle
    96 GQ coil/Cab
    08 G6eT
  5. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    growler2058 (14th July 2013)
  6. #13
    22 Post(s)
    Well I made a start on the Tray today. getting the tray off by Myself Was a bit of a Mission, but I managed it with a couple of tie down straps.
    I have tacked the head stock together and It is just resting on the mounts Atm
    I think the wheel arch is a bit too high but I will know for Sure when I flex it up and see where the wheel Sits on full compression.
    96 GQ coil/Cab
    08 G6eT
  7. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    NissanGQ4.2 (8th August 2013)
  8. #14
    looking good , are you going the hidden wiring route for any work/reverse lights fitted
  9. #15
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    Nice work we will make a show flex truck out of her yet
    Such is the rule of honour.
  10. #16
    Hey Bene, did you Friend Mick on FB? If you did have a look through his pics mate! He has done an awesome tray for is cutdown. Based on the one Biders makes. Looks sweet! Good spot for ideas
    Or jump on the Biders website for pics of their trays too.
    Are you going to do scrub rails? If so then make sure your tray width is the same width as the scrub rails
    Is this going to be ready for the October Meetup?
  11. #17
    Jun 2011
    I think so
    Dont forget your drain holes and to brace it or fully build it then gal it
  12. #18
    22 Post(s)
    I hope it's ready for October, not So Much the tray or the bull bar but the Motor Most importantly
    96 GQ coil/Cab
    08 G6eT
  13. #19
    Ummmmm? Yeah you will definitely need a Motor mate
  14. #20
    22 Post(s)
    so it may seem Lmao
    96 GQ coil/Cab
    08 G6eT
