23rd June 2013, 10:16 PM
2003 TD42Ti thermo fan under intercooler?
I am doing a conversion and have noticed that a thermo fan which is fitted to m rd28 wont fit under the td42ti due to hoses. Does anybody have a fan fitted under theirs and if so where did you get it from?
Space is minimal under there so any info would be great, the thinest i have found is 52mm, not sure if this will fit though.
Any help is greatly apreciated
23rd June 2013 10:16 PM
26th June 2013, 08:22 AM
I have not got the 4.2 but the ZD30 I have a 10 inch under intercooler it is a craig davis fan and is 60mm thick. got it from autobarn
3lt GU 111 Wagon 2 inch lift,3in Taipan exhaust, cross country intercooler,catch can,EGR blocked, dawes and needle valve,Pyro/boost gauge ARB lockers,steinbaurer chip, long range tank, s/s water tank, draws, warn winch, and other stuff.
26th June 2013, 03:33 PM
Have you tried searching quite possible someone has done it before
26th June 2013, 07:49 PM
Yeah I have had a look but all i have found is either the 2.8 or 3L the way the intercooler hose comes up is directly under it.
