Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Gq 4.2 efi auto transmission problem
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by Lambroast View Post
    Similar problem with mine. Would change from first to second, but not use third or fourth. Ended up pulling out the tranny and getting it rebuilt. When we did pull it out, opened the box for a looksee and found the plates were stuffed. Problem solvered for about 3K......
    did this only happen when cold Simon????
    Expert Lambroast's Avatar
    Perth
    Hi Todd ,
    Happened all the time. Box was pretty knackered. Glad I did take it out. Got peace of mind now knowing it's all good in there.
    Simon
    Just joined the GU club... Happy days !
  4. #13
    Sep 2010
    A little known fact is the Patrol & 300ZX share the same auto box (RE4R03A). The ratios are identical. Having done mine, I can tell you that swapping the internals is not a daunting task unless you are pulling down the valve body for a rebuild. The 300ZX box are usually cheaper to get from a wrecker and all you then need to do is swap the gear clusters, clutch and brake packs and away you go. Very easy to do
    If you wish to use the 300ZX housing, just remove the extension housing, swap the output shafts (this means removing the gear clusters, clutch plates & brakes aswell) and bolt your transfer case straight up. Your computer (TCM) should plug & play but if it doesn't and you are sure the valve body is OK, swap that over aswell.
    Depending on year of manufacture, it may or may not have a secondary revolution sensor (located at the top just behind the bell housing) for smoother changing. this will determine which housing you need
  5. The Following User Says Thank You to XLR8 For This Useful Post:
    NissanGQ4.2 (7th January 2011)
  6. #14
    Aug 2010
    17 Post(s)
    Hi Todd ,
    Simon
    mine only happens when cold, once warmed up no probs
