21st June 2013, 07:20 PM
#11
CERTIFIABLY INSANE
I already have a long range tank in mine and I picked up an 80L LRA aux tank on eBay a few months ago for $150. New they are over $1000. Will have 220L on board once its in.
Keep your eyes on eBay because they come up reasonably regularly.
The method nissan use is to pump from the Aux tank to the main tank, not draw separately so any advantage of having separate tanks is mainly lost. I intend to set mine up to draw from either. It's going to take some mucking around but it can be done. It's a bit easier with the EFI models because the pump is in the tank so there's less screwing around finding a location for the pump.
The main thing I need to do is work out how I deal with the gauge.
Tip tip tip......tap tap tap....
1997 GQ Patrol RX, TB42E. Mods: OME 2" lift, 33" BFG KM2'S, ARB winch bar & reconditioned X9 Superwinch, IPF 900 spotties HID conversion, ARB side steps and scrub bars, Kaymar rear step & spare wheel carrier & jerry holder, Rear 55W LED worklight, Safari Snorkel, 147L LRA tank, Extended diff breathers, dual batteries, GME UHF, Home built drawer and fridge slide, ARB 60L fridge.
21st June 2013 07:20 PM
21st June 2013, 07:31 PM
#12
Moderator
Look out for a sub tank on eBay, they come up for GQs all the time for bargains. Will give you 30lts cheap and keep it low and central.
A long range sub would be great and for the GQ come up often too. Gu not so often damnit!
Check out my Toy -->
Rogue Dung Beetle
21st June 2013, 07:32 PM
#13
CERTIFIABLY INSANE
Here's one:
http://bit.ly/1bUFP9G
The Following User Says Thank You to Drewboyaus For This Useful Post:
21st June 2013, 07:36 PM
#14
Moderator
Drewboyaus
eBay has heaps of these guys! If you have a GQ then you will all pick on of these up cheap on eBay. That is a 7t long range belly tank. Bolt straight in.
Rogue Dung Beetle
21st June 2013, 07:38 PM
#15
Does that fit where the original tank fits or is it an extra?
21st June 2013, 07:41 PM
#16
Moderator
mudnut
Extra! That is a long range sub tank that is a belly tank and sits under the driver
Rogue Dung Beetle
21st June 2013, 07:43 PM
#17
I suppose a heavy bash plate would have to be installed under it.
21st June 2013, 07:44 PM
#18
Drewboyaus
That's one for the petrols.. diesels don't have in built pumps. Well the mighty 4.2 doesn't..
So that's $75 for the tank. What sorta price you looking at for the dual filler neck setup?
And electrical.. there are so many ways this can be done.. ranging from $50 - $300... Lol
Owner of
Westy's Accessories
21st June 2013, 07:50 PM
#19
Moderator
Westy's Accessories
Owner of
Westy's Accessories
Nah that send is the same for petrol and diesel. I have not read his add but don't need to, the send in the aux tank has a transfer pump only and transfers to the main tank.
You would need to sort a duo filler neck but would not be a big deal to sort.
An LRA belly rank is thick and does not need a bash plate. They are bloody strong!
I would not hesitate to bolt that up to the GQ if I needed the range. Score!
Rogue Dung Beetle
21st June 2013, 07:52 PM
#20
CERTIFIABLY INSANE
There is a previous thread on this somewhere and ChrisN has posted up the installation instructions in there. It has all the kit part numbers and everything for the hoses, fillers,bolts, etc.
I've got a mate who works at ARB and I'm going to ask him to get the installation kit from LRA for me.
