23rd June 2013, 02:41 PM
#21
TD42T, larger turbo and 36ish psi boost.
3.5" exhaust from back of turbo with a straight through type muffler.
Reasonably quite, in fact quiter than most. Picked around 100-150rpm in spool time getting to full boost from the 3" I had.
Marty
The Following User Says Thank You to Bambill For This Useful Post:
23rd June 2013 02:41 PM
23rd June 2013, 10:25 PM
#22
Show off..... One day Ill get there. Maybe a built donk and compound setup like diesel tecs 55psi monster
The Following User Says Thank You to nissannewby For This Useful Post:
24th June 2013, 09:59 AM
#23
nissannewby
LOL, yeh sorry was a bit.
If it helps, I put a 3.5" exhaust on another ute the other day with a UFI 18g and DC pump with the same kind of results. He also reports a slight drop in EGT's aswell which is interesting.
Marty
24th June 2013, 10:08 AM
#24
Westy's Accessories
If I floor it, it resonates at a certain rpm, which is probably a bit too loud. But being a 1981 vehicle, I believe I get an extra 5dB allowance on the volume of the exhaust, so it might actually pass the EPA test which is at a certain rpm unloaded. It's more the sound it makes which is awesome (IMO!!).
Besides, I have it on a club rego and probably only drive it once every 3 weeks, which, touch wood, hopefully means I can avoid the fuzz. My daily is a V8 Falcon, which also sounds good!
