Could someone please tell me the location of the sender unit for the oil light on an 89 GQ, td42 motor?
Thanks in advance for the help
Cheers. Phil
Sent from my HTC One XL using Tapatalk 2
Right hand side of the block, half way down. About 2oclock from the 2 oil filters. It's a pressure switch with 2 wires
Originally Posted by Rogue Dung Beetle
The only good thing about an 80 series is..... the front end?? Wrong!!, the Engine?? Wrong!! the Full Time 4WD system?? Wrong!! Its the NissanPatrol.com.au stubby holder fitted over the transfer lever. WARNING: Towballs used for recoveries can, and do kill people and damage property.
Thanks mudrunner, do they have one for the light and one for the factory gauge as I have been led to believe by the guy at local Repco, if my photo worked does this look right to you?
Cheers. Phil
That is an oil pressure sender for sure, is it compatable with a TD42? Not sure mate, looks a little different to mine.
Not sue if there are 2 difference sensors? I doubt it.
Ok, well thanks anyway, the guy at Repco told me there was 2,one for the gauge and one for the light but stuffed if I can find anything that looks like this on the block, could see the pressure switch you spoke of with 2 wires and a rubber cover over it just in front of the oil filters, might have to go and see Mr Nissan tomorrow Cheers. Phil
