Results 1 to 5 of 5
Thread: Oil light sender location, td42
    Advanced
    Jun 2013
    Naracoorte, SA
    Could someone please tell me the location of the sender unit for the oil light on an 89 GQ, td42 motor?
    Thanks in advance for the help
    Cheers. Phil
    Sent from my HTC One XL using Tapatalk 2
    330 Post(s)
    Right hand side of the block, half way down. About 2oclock from the 2 oil filters. It's a pressure switch with 2 wires
    Advanced
    Jun 2013
    Naracoorte, SA
    Thanks mudrunner, do they have one for the light and one for the factory gauge as I have been led to believe by the guy at local Repco, if my photo worked does this look right to you?
    Cheers. Phil
    330 Post(s)
    That is an oil pressure sender for sure, is it compatable with a TD42? Not sure mate, looks a little different to mine.
    Not sue if there are 2 difference sensors? I doubt it.
  6. #5
    Advanced
    Jun 2013
    Naracoorte, SA
    Ok, well thanks anyway, the guy at Repco told me there was 2,one for the gauge and one for the light but stuffed if I can find anything that looks like this on the block, could see the pressure switch you spoke of with 2 wires and a rubber cover over it just in front of the oil filters, might have to go and see Mr Nissan tomorrow Cheers. Phil
