30th December 2010, 12:02 PM
#11
L28s have to have a fully charged battery to run
IF the battery is dying so will the motor
I had the same problem here,ran like an absolute pig, coughing and farting,stalling all sorts
Put a fresh battery in it like a whole new engine
Id go the battery route first
Then fuel filter (Usually a few $$$)
These run an electric fuel pump,so diagnosing fuel issues are easy
Take the plugs out and check for discolouration amongst them
They have a real fine filter just inside the carb, IF these block at all itll run like a pig
Take the main fuel line of the carb, its a cylinder type filter
Hard to determine from a distance ,but they are real easy to work on ,and nearly indestructable
30th December 2010 12:02 PM
30th December 2010, 04:07 PM
#12
Just read in your intro that the car was stored for 4 years ???
If this is the case,replace fuel and filters straight up
Fuel will be stale and will be rubbish ,throw it
Then check fuel lines for cracks and splits,actually replace it as well
Only cost a few $$$ (Good peace of mind)
31st December 2010, 06:09 AM
#13
hey ,
i already replaced the fuel, but in the beginning i started to search for a ignition problem.
its not leaking fuel but maybe blocked somewhere indeed..
first thing tomorrow morning is filter replacement and carb cleaning.
i`ll let you know what happened after that
thanks for your help
