Results 1 to 6 of 6
Thread: RD28 Starting issues
    Mar 2013
    Im having a bit of a problem when I start my GU RD28 in the morning. It seems to start OK but after about 10 seconds at rattly noise starts and goes away after about half a minute, might be one of the injector getting air in it but im not sure. Anybody had a similar problem?
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Never had that problem when I had a 2.8 in mine, I think the easiest way to check if its an injector would be to crack each injector line and see if the noise returns, it could also be that the injector is dribbling and it takes a little time to build up pressure in the injector, again cracking each line should help you isolate it. How old are the injectors, could also be that the oil pump might be getting a bit tired. Without hearing, it would be hard to give an accurate diagnosis. When I had a 2.8 in mine my starting issues began with the fuel pump and got steadily worse from there.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
    Mar 2013
    Seems to be something to do with the injectors might have to get them out and have the serviced? What have you put in yours now?
    Sep 2011
    Australia
    Chevy 6.5, expensive but haven't regretted it yet. Sure puts the willies up people at intersections when they think that they can pull out in front of some old 4wd and then I am right there on top of them.
    Sep 2011
    Australia
    Don't want to buy a consult interface do you, I have one for sale in the parts for sale section that I no longer require
    Mar 2013
    Put in some reconditioned injectors in and it starts and runs sweet now
