Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Waterlogged GU
    Patrol Guru Morton's Avatar
    Sydney West
    not sure in the GU's but the GQ have a small tube in the bottom corners of the front windscreen, these tend to block up with gunk & cause the windscreen to leak on both sides, this is fitted for when water gets behind the seal & this allows it to weep out,
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  2. The Following User Says Thank You to Morton For This Useful Post:
    Ian2011 (18th June 2013)
    us poms are crap at cricket fracster's Avatar
    North West England.
    Has it got a sunroof?
    It is now official, we are not quite so sh@t at cricket as we were! Rugby Union is a different matter.
  5. #13
    Patrol Guru paulyg's Avatar
    Ballarat
    Thanks Cuppa, I see what they are now.
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
  6. #14
    Jul 2012
    There is a previous thread similar to this issue, try reading. It could be the drain pipe from the aircon evaporator that is not draining well. The pipe could be clogged when you went thru deep water. try declogging it and give an extension pipe.
  7. #15
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Quote Originally Posted by alexx View Post
    I am able to read mate, didn't need some smart a@#e comment from you. Sometimes first hand info is better then spending hours trying to search with the right keywords. Thanks to all others who provided some good info, will have a good look on the weekend to see if I can locate the problem.
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
  8. #16
    Jul 2012
    Quote Originally Posted by Ian2011 View Post
    Sorry if I offended you on this thread. I didn't mean anything other than saying for you to read that for that thread was expounded enough for anyone to look easily on the drain pipe issue if that appears to be your problem with your vehicle..
    I posted on that thread trying to share a first hand info as you have stated as the better info. It was my personal experience having flooded passenger carpet, if you may want to know.
    Be patient to look into any thread.
    I don't know if I'm right, double posting of any thread is prohibited. Moderators of this forum, can you appraise us on this?
  9. #17
    i don't know if I'm right, double posting of any thread is prohibited. Moderators of this forum, can you appraise us on this?
    No mate there is no harm in posting a thread that has been covered already. You might get asked to use the search. If I see a thread I know has been covered before I generally search for the thread and post the link to it.
    If you're happy and you know it tap a post!
    alexx (20th June 2013)
  11. #18
    Sep 2011
    Australia
    No worries Alexx, wasn't really offended but just thought the way your comment was written was implying I hadn't already done some research. No Harm, no Foul.
  12. #19
    Hi Ian
    Did you ever get to the bottom of this leak. I have the same thing goin on. Water leaking in at the top of the a pillar and dripping of the grab handle. Have had the screen out and resealed twice. I do not have a sunroof so thats not the problem. Any info you could provide would be greatly appreciated.
