6th April 2016, 11:31 AM
#61
janderson
A turbo vehicle will only use the air that is needed, any more and it is expelled out the wast gate. So I would think forced in air is a small factor. As a turbo will suck the air that it needs, so then facing the snorkel to the back should not matter other than supplying cleaner air. Threedogs is also right, coming up to the Murray is all up hill.
Not quite. Waste gate gets rid of exhaust gases which in turn controls turbine speed and boost. In a diesel with no throttle body, the motor will take all the air it can.
6th April 2016 11:31 AM
6th April 2016, 11:33 AM
#62
twisty
Backwards for me as well. 4.5 lpg/petrol.
With the inlet forward the engine dies when slowing below 40kph (leaning out?). Economy 25l/100k either way. 4 different mechanics, thousands of k's and no one knows why! A mate with a TD42 swears forward facing gives better power and economy.
Give it a try.
Pretty common on gas motors. Pretty sure there was an equalization pipe or similar that once installed would resolve the issue. Otherwise, turning the snorkel backwards works too.
#63
And sorry, didn't realize previous poster have gravedug so far back
9th March 2017, 09:09 PM
#64
Came across this thread by mistake but had me intrigued, has anyone else tried ?
I turned mine round and seem to be getting more power , not sure about fuel consumption just yet .
