13th June 2013, 07:42 PM
duel battery
hello people
I have a 4.5ltr 2001 gu2 and I was looking for a post about duel battery set ups and battery placements under the bonnet. any help would be great
thanks guys
aj
13th June 2013 07:42 PM
13th June 2013, 07:46 PM
not sure its possible if running dual fuel, some have fitted battery in the cargo area
13th June 2013, 08:17 PM
hello threedogs
sorry I should have said so no duel fuel. I don't want any thing in cargo area as I have 4 kids and use up all free space with there crap. looking at moving stuff around under the bonnet to fit it in. and was looking for ideas.
thanks for such quick response
aj
13th June 2013, 08:29 PM
Legendary
aj,
You could try Pirahna OffRoad - they have excellent systems of which I have one.....
Here is an ebay link to one of their trays
http://www.ebay.com.au/itm/DUAL-BATT...-/400374640633
Mic
13th June 2013, 11:06 PM
CERTIFIABLY INSANE
I'm quite happy with my Redarc setup.
Piranha is ok too.
Tip tip tip......tap tap tap....
1997 GQ Patrol RX, TB42E. Mods: OME 2" lift, 33" BFG KM2'S, ARB winch bar & reconditioned X9 Superwinch, IPF 900 spotties HID conversion, ARB side steps and scrub bars, Kaymar rear step & spare wheel carrier & jerry holder, Rear 55W LED worklight, Safari Snorkel, 147L LRA tank, Extended diff breathers, dual batteries, GME UHF, Home built drawer and fridge slide, ARB 60L fridge.
14th June 2013, 02:42 PM
we once had a strange brakedown with dual battery installed, sometimes the car would run, then stop without electricity, then get it back and run again, then stop... the ground cable was broken within its protective surroundings and contact was intermittent. use good cables with appropriate length to avoid tensions on it
