Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: GU4 Tail lights in a GU1
    yeah does not look like they built in the bloody Indicators!! Why would you not put Blinkers In??
    They look good but if they are not Full Function then there is little point IMO.
    Expert florix's Avatar
    Casino
    thats it hey. hopefully its just a simple add the wiring to suit but $300 for just LED break lights is a bit too much.
    If I can use my lights wiring for the reverse and indicator then maybe...hmmm
  4. #13
    Feb 2012
    Hi,
    I fitted GU4 to my GU1 Patrol. I had to remove quite a bit of metalwork inside where the light goes. I then had to weld in a couple of reinforcing struts to strengthen, as these parts removed were strengthening for the rear doors. You then have to cut the outer panelwork back so the lights sit back enough. The mounting pins are then the same as series 1. Just need to seal the lights to the panel then with silicone or similar. Quite a bit of work, but looks good. I would have thought twice about starting if I knew how much work it was going to take.
  5. #14
    Quote Originally Posted by 04OFF View Post
    From the picture, it looks like there is no bulb holder or LEDs in the indicator and reverse lens area/s, IMO, the best thing about aftermarket tail lamps, is you end up with working 2 reverse lamps , might pay to double check if these parts in the lights do in fact work ?
    Heres mine with 4 x led globes and an extra 36 watt n top,
    wouldn't having smoked good as they look give less light.
    reversing in the bush is a breeze with these lights
