Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: GU Bumpstop query
    Apr 2013
    GU Bumpstop query
    Does anyone know what is the best way to make GU front bumpstops longer ? Also does anyone know if it is legal or not ?
    cheers
    North brissy
    80's series ones spaced down. Not sure about legalities.
    Advanced Steveo_the_Devo's Avatar
    Oct 2011
    Wollongong NSW
    Or pick up aftermarket extended bump stops
    2011 CRD with a bunch of stuff bolted on
    330 Post(s)
    Front or rear?
    80 series bump stops are 150mm long and are readily available on ebay with conversion plates to bolt straight into the back of a GU
    how long do you need?
    Nissan-Rear-Bump-Stop-Conversion-kit-PAIR
  6. #5
    North brissy
    Front or rear?
    For the front. 80's serious bolt into the front as well.
  7. #6
    330 Post(s)
    Yes teh rear bump stops out of an 80series are 150mm long and i run them in the front too but have spaced my shock towers up 50mm. Bolt straight in
  8. #7
    330 Post(s)
  9. #8
    Apr 2013
    Correct me if im wrong, but dont the 80 series bump stops compress to a shorter length instead of being one solid unit like the patrols ? Do you need those adapter plates in that ebay link you posted for both the front and rear ? Also do you know if those shocker tower spacers are legal ?
  10. #9
    330 Post(s)
    1. Yes the 80 Bump stops are progressive.
    2. Really depends what you actually want the bigger bump stops for? you have not told us yet
    3. you only need the adaptor plate to fit to the rear. they bolt straight into the front tower.
    4. No Idea If you dont have a Body Lift you may not have the room to fit them anyway
  11. #10
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Everything is legal untill you get caught...
    Owner of
    Westy's Accessories
