12th June 2013, 11:00 PM
I want to run larger tyres. Any idea what the length of an 80 series bumpstop is when compressed ?
12th June 2013 11:00 PM
12th June 2013, 11:06 PM
Moderator
mtbrider4life
Running larger tyres won't affect your bump stop needs in any way at all.
The only reason you would get your bump stops is if you were running extra long shocks beyond your spring lift. ie. 6" shocks and 4" Springs.
Check out my Toy -->
Rogue Dung Beetle
12th June 2013, 11:43 PM
MudRunnerTD
It can if your worried about scrubbing. Helps a bit on the rear for this reason but the front should be fine with out due to its different setup to the rear.
13th June 2013, 12:26 AM
Moderator
nissannewby
agree. maybe look at swapping the rims for a bigger offset for the big tyres if your looking to run 2 sets?
Rogue Dung Beetle
