10th June 2013, 08:54 AM
Winch wiring, multi point ?
Calling all electricker types
I've been trying to be clever with my winch controls.
I have a master switch on the dash, ON/OFF/ON to send power to the aerial up/down switch on the dash that now controls winch in/out. The ON/OFF/ON switch also sends power to the outside wander lead when switched to the other ON position. So only inside OR outside controls for the winch , not both for obvious reasons.
However I've hit a snag, when the outside ON is used the outside controls only make the solenoid clunk, ie there's not enough volts hitting it ? I think I'm getting voltage drop by sending power back into the truck loom. I think
So my long winded question, Can I fit a diode or something at the outside end to stop me loosing power back into the truck ?
PS inside ON works fine with the aerial up/down making the winch go in and out
Y60 Patrol 4.2 d SWB in puke green
2" body lift, 2" pedders suspension lift, 35" Simex muds on excel 16" alloys, needs a turbo :/
10th June 2013 08:54 AM
10th June 2013, 10:18 AM
Moderator
It should not make any difference unless you have wired it incorrectly.
Essentially both circuits as Switching circuits only. They both Only switch the Solenoid. The winch relies on the power from the battery to the solenoid to the winch. Full stop.
All or your switching is only to operate the solenoid (relay). Recheck your wiring.
Note also that the switch you have used for your I cab control should be a "momentary On" switch. I am not sure that that factory switch is?
On - Off - On is to suitable for an incab switch.
It MUST be Momentary On - Off - Momentary On
Hope that helps
Check out my Toy -->
Rogue Dung Beetle
10th June 2013, 10:21 AM
Moderator
Note also that the aerial switch "may" be switch negative? Guessing. This may cause further issues as you would then have alternative switching circuits I think? Getting above my head now I declare.
If the switch is suitable as above then run a twin core straight to the battery to the back of that switch and see if it functions? If it does then its the loom and bypass it.
Rogue Dung Beetle
10th June 2013, 07:18 PM
Thanks for that. The aerial switch is momentary
The on/off/on isnt but was on an external winch solenoid previously.
I'll try a new cable now as suggested . I was just thinking the old power aerial plug under the wing was so convenient , doh !
Back in a bit lol
