Results 31 to 39 of 39
Thread: DIY Rear wheel bearings & seals
  1. #31
    Apr 2013
    central coast
    D y i wheel rear bearings & seals
    Now that you have made sure everything is clean slide the axle back in BUT DO NOT REST THE AXLE ON THE SEAL THAT YOU JUST INSTALLED INTO THE HOUSING as you slide the axle into position rotate it as you push & try to lift the slpined end up as you push it in so it will slide into the planetary then tighten all the nuts up & refit the disc & caliper
    When doing this repair just take your time & think ahead theres no rush & remember its easier to fix a stupid question than it is to fix a stupid mistake
    Any questions just ask
    My next job hopefully will be to rebuild a 5speed & transfer box & replace a 5th gear shaft
  2. The Following 3 Users Say Thank You to jgoose For This Useful Post:
    BrazilianY60 (15th February 2024), dom14 (3rd July 2015), Robo (10th February 2016)
    173 Post(s)
    Jgoose, this is a job I hope I don't have to do, but nevertheless I thank you very much for posting as you have. I now have a much better idea of 'what's in there' & if I were ever in a situation where I had to undertake this task could do so with greater confidence. Good one mate.
    Cuppa
  5. The Following 2 Users Say Thank You to Cuppa For This Useful Post:
    BigRAWesty (17th June 2013), BrazilianY60 (15th February 2024)
  6. #33
    Patrol Freak gaddy's Avatar
    redlands
    Great write up , it's always great when guys like you share your knowledge ,
    Steve
  7. #34
    Great post Bloke, I'll be running my axles down to my local mechanic to get the pressing done I recon, how long did it take to do the job and get back to that box of cans? Excellent photos as well.
  8. #35
    Legendary happygu's Avatar
    Great post JGoose, and some great tips for all of us which we can apply to a multitude of jobs, and with some more agricultural tools too.
    mic
  9. #36
    Apr 2013
    central coast
    Hi all thanks for the kind words i relise its not a job for everyone i just like to show ppl how things can be done without paying top dollar at least a lot of the job isnt too hard to tackle at home then take the axles to the mechanic for the pressing side of it
    this took me around 4-5hrs plus i greased the car & changed all the oils as well. I Smashed the rum had to grab another couple of cubes ill be fitting wheel sensors soon if anyones interested.
    . If any one needs any help all you need to do is ask
  10. The Following 3 Users Say Thank You to jgoose For This Useful Post:
    BrazilianY60 (15th February 2024), dom14 (20th November 2016), jayisbikes (31st August 2014)
  11. #37
    Advanced jayisbikes's Avatar
    Jul 2014
    Thanks jgoose, I'll give it a go !
  12. #38
    Mar 2017
    That's a great job, much appreciated.. Thanks for taking the time and sharing that procedure.
  13. #39
    Jul 2021
    Hey sorry to dig up an old post, I have just done a wheel bearing on my gq axle, the torque spec was around 450nm, then back off and preload to spec. I have backed off the lock nut and the preload is still 120nm, this seems waaaay to tight or will it loosen up as the new bearings break in. Do I just lock the nut so there is no play in the axle and hope for the best or is there something not quite right here?
    Thanks for any help
