6th June 2013, 11:10 AM
DZ30 cracked pistons
I have a 2003 3l turbo diesel standard. Had bubbles in the coolant. Got the head removed to do the head gasket. Found cracked head and cracked pistons.
What do I need to do to stop this from happening again?
6th June 2013 11:10 AM
6th June 2013, 11:12 AM
BoojaBear
Hi mate. As I said in your introduction, have a search for NADS. It stands for Nissan Anti Detonation System. It is a series of steps you can take to prolong the life of the zd30 engine and stop it from "detonating".
Sig test. android, MC version 2.4.7.11
Hello from Under Down Under!
The Following User Says Thank You to taslucas For This Useful Post:
threedogs (6th June 2013)
6th June 2013, 11:16 AM
Fitting a manual boost controller will stop this happening, it takes all thinking away from the ECU and you control how much boost.
After your rebuild highly recommend NADS , as per other thread check archives on NADS written by Chaz Yellowfoot {guru} on
this subject, heaps of pics easy to follow instructions as well.. First rebuild if thats your wish, start getting your NADS together.
Best thing you can ever do, highly recommend.
6th June 2013, 06:11 PM
i must agree with 3D. do yourself and your patrol a favour and do the nads. the worry of driving and watching those 2 important gauges [boost/pyro get them if you have not got them yet] ] go to danger levels. its not 100% but you will sleep better at night knowing you have done the best for your zd30. go the nads!
3lt GU 111 Wagon 2 inch lift,3in Taipan exhaust, cross country intercooler,catch can,EGR blocked, dawes and needle valve,Pyro/boost gauge ARB lockers,steinbaurer chip, long range tank, s/s water tank, draws, warn winch, and other stuff.
