Results 1 to 10 of 19
Thread: Falcon xr seats into gq
    Expert lg 91's Avatar
    Apr 2011
    central coast nsw
    Well as the title says I've installed a set of ba/bf xr front bucket seats to my gq so here's abit of a write up on how to do it.
    First off all get the xr seats and remove the original rails these are not needed.
    Then remove the seats from the gq and remove the rails from seats I put the rails back in so I could work out the hights of the rails.
    The outer rail needs to be raised 25mm I used abit of shs
    Then notch the shs to suit the rail and drill holes to Match
    Then drill a hole in the original bracket to suit the xr seat
    Then you need to modify the inner rail as its about 50mm to short I just made a plate to fit the full length of rail
    Then I attached the plate through the original real hole and drilled a new one to suit in the plate then you have all the holes were u need them for new seats.
    Then we come to the seats them selfs when I put them in they were touching the pillar you could modify the rails to move over about 30mm but I did something different I swapped the seats around so iam using the passanger side for drivers and so on then you have enough room for all the adjusters of the seats
    To make the seats look right remove the plastic panels and swap them around
    Then drill this one out 30mm so the adjuster fits
    Than bolt the seat down and ur done
    I still haven't done the passanger side but should be simaller to the drivers but ill post some pics if any things different
    Enjoy the comfort
    06 gu4 dx zd30 with toughdog adjustables, swaybar discos, custom built rearbar sliders and cargo draws, 305/70/16 maxxis bighorns, warnxd9000 with rope,ipf spoties,provent200,boost and egt gauges.
    89 gq swb tb42 auto soon to be the weekend offroad toy
  2. The Following 7 Users Say Thank You to lg 91 For This Useful Post:
    AB (18th June 2013), Bloodyaussie (29th June 2013), Clunk (5th June 2013), Family4x4 (9th February 2015), graeme1969 (18th June 2013), NissanGQ4.2 (5th June 2013), Roscoe (7th May 2014)
    Expert graeme1969's Avatar
    Jun 2013
    Wesley Vale, Tas
    Nice work.
    Was the finished sitting position at a similar height to the original seats?
    Graeme
    43 Post(s)
    Nice work. And clever thinking with the swap over..
    If you don't mind me asking what sorta price did you pay for the pair?
    Owner of
    Westy's Accessories
    Awesome job mate, it's a mod I want to do eventually. I reckon they are so much nicer than the Commodore seats. There is another write up by member Great Southern Camping of the same install.
    The seats look good. in NSW, do you need to get the vehicle checked for the mod? I'm interested to find out how the seats feel on rough terrain.
    Hardcore healy's Avatar
    south east melbourne victoria
    My neighbours has 2 XR seats mate I think he wants $150 for both and they are excellent condition
    IF ITS NOT BROKEN IT MUST BE A PATROL
    43 Post(s)
    Quote Originally Posted by healy View Post
    Could you investigate this mate. I maybe keen
    Owner of
    Westy's Accessories
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Certainly do mate, I don't think any state in Australia allows you to change from standard seats without getting it certified by an authorised certifier.
    Legally if you pull your rear seats out it needs to be inspected!
  11. #9
    Owner of
    Westy's Accessories
    Yeah no worries ill talk to him in the morning I have seen them I was going to put them into the GU they are in really good condition absolute bargain in my opinion ill let ya know
  12. The Following User Says Thank You to healy For This Useful Post:
    BigRAWesty (19th June 2013)
  13. #10
    Apr 2011
    central coast nsw
    Hay fellas sorry for the late reply i paid $200 for the pair they are maybe a little bit higher than the originals but iam 6'2 tall so its better lol.
    I haven had the seats mod plated bu it on the todo list with many other things that need to be inspected lol
