Results 21 to 30 of 43
Thread: Oil Filters
    Patrol Guru Drew's Avatar
    Western burbs of Melbourne
    Possibly. With filters with a better anti drain back in them you should only get 100ml approx spill. If the filters were vertical then the size of the filter head would determine how much oil will be spilt.
    It comes down to room constraints really, you could remote mount them but this could harder than its worth.
    It isn't the best setup but it is still one of the easiest in a passenger vehicle. Ask a new cruiser owner where there oil filter is and for a laugh where the starter is
    oh come on don't leave us hanging, i need a laugh today.
    2008 GU 3.0 CRD Auto - Life's too short to eat bad food.
    OK found the guy that does the Oil catch trays for the TD42. i will let you all know details soon.
  4. #23
    Quote Originally Posted by Drew View Post
    Starter motor is in the valley. It's a 12 hr job to change one. The oil filters are jammed under neath in a cartridge style filter.
  5. The Following User Says Thank You to nissannewby For This Useful Post:
    Drew (6th June 2013)
  6. #24
    12 Effin hours !! ........ Drew picks himself up off the floor and wipes the tears of laughter away .... oh that's sad but I suppose they don't go too often.
  7. #25
    You'd be surprised. Many have gone inside the 50k mark
  8. #26
    Ouch that's gotta hurt
  9. #27
    Expert Big Red's Avatar
    Feb 2012
    These Ryco Oil Filters all have the same thread but different diameters and lengths
    thread info = 3/4-16-UNF-2B
    model - Thread-seal dia-dia-length
    Z9=3/4"-16-UNF-2B, 70-94-142=ford
    z170=3/4"-16-UNF-2B, 70-94-99=2.8 petrol MQ Patrol
    z115=3/4"-16-UNF-2B, 70-94-142=4.0 petrol MK Patrol
    z170=3/4"-16-UNF-2B, 70-94-99=4.2 petrol carby GQ Patrol
    z115=3/4"-16-UNF-2B, 70-94-142=4.2 diesel GQ Patrol
    z145a=3/4"-16-UNF-2B, 63-82-102=3.0 petrol GQ Patrol *** check seal surface to make sure seal fits!
    z503=3/4"-16-UNF-2B, 70-94-127=one of the TD42 filters GU non turbo Patrol
    z503=3/4"-16-UNF-2B, 70-94-127=one of the TD42T filters GU series 1 Patrol
    So i can use the Z9 on the above as they are much cheaper and more available.
    Note*these filters below are different thread sizes.
    R2154P = cartridge filter, G60
    R2419P = cartridge filter, MQ SD33 diesel
    Z149 = 1"-12-UNF-2B, 70-94-178= MK SD33 non turbo and SD33T turbo diesel
    Z416 = 1"-12-UNF-2B, 70-97-127 is used on 2.8TD and second filter on GU TD42 non turbo and TD42T turbo diesel series 1
    Z547 = M20-x1.5-6H, 63-68-86= 4.5 and 4.8 petrol Patrol
    R2593P = cartridge filter, 3.0TD Patrol
    You can follow me but its gunna hurt !
  10. #28
    174 Post(s)
    Are there any disadvantages with using z9’s in place of z503’s?
    I only ask because I have a couple of z9's sitting in a cupboard from when I had an Falcon.
    Do they have an anti drain valve?
    How do they go fitting into the limited space on the TD42i as I think they are a bit longer?
    Cuppa
  11. #29
    174 Post(s)
    Hi, I have a 2006 Nissan Patrol, with the 4.2TDi diesel motor. Normally I use Z503 oil filters. However I have a couple of Z9 oil filters sitting in a cupboard. They have the same thread as the Z503's & both types have an anti drain back valve, so I am wondering if there is any reason I should not use the two Z9's on my next oil change? I would welcome your advice on this.
    Thanks,
    Hello Cuppa
    Thank you for your enquiry. The two filters while looking similar we do not recommend as directly interchangeable as they have different internal valving. The Z503 only has anti-drain back valve whereas the Z9 has the anti-drain back valve and a relief valve. Our recommendations are designed to ensure that the filter works to it maximum specification and performance for that particular application. We recommend you use the correct filter for your vehicle to ensure that you have the maximum coverage of our warranty in the event you were to experience any problems. Hope this information is useful.
    Regards Ryco Customer Service
    Elsewhere I read a response to the same question from Ryco which said you could use the Z9 in place of the Z503 but not the other way around,....... but do so at your own risk, our warrant wont cover you.
    Cuppa
  12. #30
    Well??????
