Results 1 to 9 of 9
Thread: Extra rear step
    Extra rear step
    Hi all. I've come up with an idea to allow access to your roofrack safely.
    Can,t give too much away but will have working model of one by the end of the week.
    It will be "rated' to except 150 kg, If your bigger sorry I can't help. In the meantime heres one that'll be similar to look at only, This will be powder coated Yellow and bolted to the side of my Faux wheel giving me access to the roof rack another piece of checker plate will be rivetted to top of faux wheel. Might have to use Billy bleed as a crash tester, lol. Reasonably confident it'll work first time. you will not need to drill any holes with my design. its easy as really. stay tuned.
  2. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (3rd June 2013), oncedisturbed (4th June 2013), twase (4th June 2013)
    @P4trol was thinking of that but found an easier way that'll fit all 4x4 with wheel on door or swing away.
    If Nissan didn't put the lump in middle of the rear wheel holder and had nuts instead of studs , life would
    be so much easier
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Extreme limits off road do a similar one of these aswell
    http://www.ebay.com.au/itm/4x4-Rear-...-/230986605882
    Thanks MEH ,never saw that, but mines a lot different, You can use over centre catch, This is for the DIY guys and gals.
    Some chain ,scrap checker plate, mine I'll be powder coating black and highlighting tread in yellow. when all tensioned up should support your weight till you're standing on top of spare. now off to powder coaters. satin black.
    Chain should bite into rubber of spare
    BigRAWesty (4th June 2013)
  8. #5
    43 Post(s)
    Looking good TD.
    Owner of
    Westy's Accessories
    Oct 2010
    Old Bar, NSW
    Very clever, making it safe to climb with wet boots etc.
    Easy to pack away if not needed as well.
    Good luck with it
    Macca
  10. #7
    G'day 3D. I was thinking of the same sort of thing, but making it to fit into a snow chain on the spare. I can't lift anything overhead, so I don't even have a roof rack, but the extra step would make me consider getting one. I don't know the laws regarding snow chains, but I've always wanted to try them to get through mud.
  11. #8
    Snow chains are frowned upon out bush as they just rip tracks to shreds
    Be easy enogh to retro fit to snow chains ,maybe easier, just make step
    so it clamps onto chain.
    Going to go another way, as was pointed out to me by Kallen ,way to many tyre variations,
    I have plenty of laser cut brackets to put one in centre of wheel, just thought this would work better.
    Been thinking of colour for my one too, all yellow or all red will look stupid, so I'm powder coating it
    Satin black and I'll highlight the tread pattern on the steel by hand either white or yellow, need to see what enamel
    is lying around
  12. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (4th June 2013), mudnut (4th June 2013)
  13. #9
    43 Post(s)
    Good to hear I'm of assistance.. was wondering if you got my pm..
    Owner of
    Westy's Accessories
