Results 1 to 3 of 3
Thread: RD28 gearbox sound diagnostic
    Beginner 2.8PWR's Avatar
    I hope this helps anyone with a rattle/groan coming from their gearbox behind a 2.8 or 3.0 petrol.
    If you're noticing a rattle at idle that sounds like its coming from the bellhousing, its most likely not the clutch. If you play around and you find the noise is only with the clutch engaged, it is a gearbox bearing. Also if you notice the noise goes away on 4th gear, it is a countershaft bearing. I had this bearing fail in my gearbox, and after pricing up various rebuilds, I just swapped it with a low K second handie. The metal in the gearbox oil is a dead giveaway.
    1998 GU Wagon, RD28ETI, Custom Exhaust, Chipped, Go Baby Go Switch, No plans to swap it.
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Got any pics of the carnage?
    Advanced
    Jun 2013
    Norway
    In my patrol I have alot of rattle sound! Sounds very bad in 3th and 5th gear. No sound in 4th gear. Does this mean it's a countershaftbearing that is broken? Is there a countershaft for 1st and 2nd gear, and one for 3th and 5th?
    Regards,
    Jakob
