Results 1 to 10 of 13
Thread: zd30 help required please
    sydney
    hi all
    my 01 gu is starting to play up a bit
    it has had a lack of power for a while now and its getting worse and worse. at first i thought it was bad turbo lag but now i think its something wores.
    it starts fine idles fine and its not blowing smoke but its lacking power big time and occasionaly the engine light was coming on.
    i changed the fuel filter and it run a little better for a few days, then i cleaned the mass air flow sensor with the proper spray and the engine light stays on now and its still running like a bag of s*#T !
    also i have noticed a fair amount of oily residue on the air filter the last three or four time i have changed it,
    Should i go out and get a new maf sensor and would this fix the problem or is it sounding like a injector pump or turbo problem
    any info would be greatfull
    cheers
    43 Post(s)
    Hay mate, not to sound rude but have you researched your question??
    Heaps of info on your issues in the gu section, and I'd say it is the MAF sensor without owning a 3ltr, just from what I've read.
    But it sounds like you've left it A long time. You may need to pull the intake system off and give it a good clean..
    Owner of
    Westy's Accessories
    Get yourself a can of MAF cleaner from SCA remove MAF and spray heaps ,.Allow to dry and re fit.
    Might also be time to think about fitting up your ride with NADS,
    Search Chaz Yellowfoot ing the archives heaps written Pics what and where to buy.
    Where do you live. You could try my MAF if it helps.
    Legendary happygu's Avatar
    Definitely sounds a little like the classic MAF problem.
    As Mudski said, try and find someone in your area who has a spare, or is willing to let you try theirs to see if it helps
    Mic
    Is it me or did I miss he's from SYDNEY lol
  8. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (29th May 2013)
  9. #7
    sydney
    hi guys yes i have done some reserch but not shore of anything else to try
    i have got the sca maf cleaner and give it a good soaking yeterday and still hasent worked
    im worried about the engine light being on and not shore if this is doing damage while driving
    i read that after cleaning the maf to disconect the batt and this will reset the computer and switch the engine light off but that hasent worked eather
    im on a tight budget and just trying to eliminate the cheapest stuff first
    cheers
  10. #8
    43 Post(s)
    Try and find someone with a diagnostics computer at find what fault is throwing the engine light.. not sure of your instrument cluster but I'm guessing you have oil pressure?
    Owner of
    Westy's Accessories
    sydney
    thanks kallen ill try take it to get looked at im not shore were to get from here
    thanks guys for your help
  12. #10
    43 Post(s)
    Unfortunately I can only suggest a good mechanic. Ring around first and get some prices to diagnose.
    Owner of
    Westy's Accessories
