29th May 2013, 06:32 PM
zd30 help required please
hi all
my 01 gu is starting to play up a bit
it has had a lack of power for a while now and its getting worse and worse. at first i thought it was bad turbo lag but now i think its something wores.
it starts fine idles fine and its not blowing smoke but its lacking power big time and occasionaly the engine light was coming on.
i changed the fuel filter and it run a little better for a few days, then i cleaned the mass air flow sensor with the proper spray and the engine light stays on now and its still running like a bag of s*#T !
also i have noticed a fair amount of oily residue on the air filter the last three or four time i have changed it,
Should i go out and get a new maf sensor and would this fix the problem or is it sounding like a injector pump or turbo problem
any info would be greatfull
cheers
29th May 2013 06:32 PM
29th May 2013, 06:36 PM
Hay mate, not to sound rude but have you researched your question??
Heaps of info on your issues in the gu section, and I'd say it is the MAF sensor without owning a 3ltr, just from what I've read.
But it sounds like you've left it A long time. You may need to pull the intake system off and give it a good clean..
Owner of
Westy's Accessories
29th May 2013, 06:40 PM
Get yourself a can of MAF cleaner from SCA remove MAF and spray heaps ,.Allow to dry and re fit.
Might also be time to think about fitting up your ride with NADS,
Search Chaz Yellowfoot ing the archives heaps written Pics what and where to buy.
29th May 2013, 06:58 PM
Where do you live. You could try my MAF if it helps.
29th May 2013, 07:12 PM
Legendary
Definitely sounds a little like the classic MAF problem.
As Mudski said, try and find someone in your area who has a spare, or is willing to let you try theirs to see if it helps
Mic
29th May 2013, 07:15 PM
Is it me or did I miss he's from SYDNEY lol
The Following User Says Thank You to threedogs For This Useful Post:
BigRAWesty (29th May 2013)
29th May 2013, 07:18 PM
hi guys yes i have done some reserch but not shore of anything else to try
i have got the sca maf cleaner and give it a good soaking yeterday and still hasent worked
im worried about the engine light being on and not shore if this is doing damage while driving
i read that after cleaning the maf to disconect the batt and this will reset the computer and switch the engine light off but that hasent worked eather
im on a tight budget and just trying to eliminate the cheapest stuff first
cheers
29th May 2013, 08:02 PM
Try and find someone with a diagnostics computer at find what fault is throwing the engine light.. not sure of your instrument cluster but I'm guessing you have oil pressure?
Owner of
Westy's Accessories
29th May 2013, 09:03 PM
thanks kallen ill try take it to get looked at im not shore were to get from here
thanks guys for your help
29th May 2013, 10:11 PM
Unfortunately I can only suggest a good mechanic. Ring around first and get some prices to diagnose.
Owner of
Westy's Accessories
