Results 11 to 20 of 25
Thread: Td's rear bar
    Plus my eldest pinched the front bar for his 4x4 project, Dual cab lux with 253
    Better than nothing isn't it?
    If someone made a nice looking rear bar out of painted or powder coated alloy I would buy one. Those bars are quite heavy and these lil ZD30's struggle enough now.
    I've never seen a GU rear bar made out of alloy but to me it makes sense to use alloy. Properly made and with strengthening folds and internal bracing in the right places they would be more than strong enough for what most people would need and be half the weight - GU Kaymar bar weighs around 80kg, although that does include a towbar which wouldn't be possible with alloy.
  4. #13
    I'm sure there would be a way to design one though where you could use the standard tow bar bracket. ..
    I tapped that app
  5. #14
    You would need the plastic rear bumper, but that leaves you with out tail lights.
    If anyone has even one at home I'd be interested in it.
    OE tow bar bracket would be the chassis, very easy just to do one piece rear.
    I'm thinking more like OE but slim line
    Don't think an alloy rear bar would be cost effective, material/welding would cost
    a fortune
  6. #15
    Hardcore healy's Avatar
    south east melbourne victoria
    a fortune
    If your talking about a rear bar for gu I might be able to help
    Sent from my GT-I9505 using Motorculture mobile app
    IF ITS NOT BROKEN IT MUST BE A PATROL
  7. #16
    Yeah Heals Just need something that gets me started, shape wise, what you got in mind???
  8. #17
    Ive got the rear bar on ny car you can have ive gotta see george at some stage so maybe someone up that way wouldnt mind if I left it somewhere for you to pick up as I got no need for it
  9. #18
    Yeah leave with George I'll Grab it from there if its ok with you, hopefully I can come up with an after market bar for the earlier GU
  10. #19
    80 Post(s)
    a fortune
    $65 an hour at my local exhaust place. If you have all the bits and pieces wire brushed, clean and ready to go, a good tradesman should be able to finish the job fairly quickly if your design isn't too complex.
  11. #20
    Hopefully I can design a replacement bumper that can take a hit and not pop off
