26th May 2013, 10:36 PM
RD28 Turbo oil leak
Had an oil leak for a while, think I might have traced the source, yesterday I noticed oil leaking out of the rubber input hose from the turbo to the intercooler. I think I may have a crook oil seal in the turbo, is this a difficult fix?
26th May 2013 10:36 PM
27th May 2013, 10:47 PM
Looks like I might be up for a another turbo any ideas where I may be able to get one? Is there an aftermarket Turbo that will give me a bit more power that will bolt straight in?
28th May 2013, 10:04 PM
Is your egr system (purposely blocked?
Take your intercooler out and see if the whole thing is oily. If so, get some petrol and clean it out. Unscrew the sensor in the intercooler and also get the oil off it.
Also clean both hoses (inlet/outlet) to intercooler. That gunk is making its way into your engine!
28th May 2013, 10:07 PM
As above. The engine crankcase breather is generally routed so it goes into the intake pre turbo and after a while builds up a little bit of oil. I would be cleaning all of the stuff the above has mentioned and go from there.
PS, when refitting intercooler cleaned with petrol, let the residual evaporate as much as possible. Then fit it back and connect everything except the hose between intercooler and engine intake. Start engine and slowly connect last hose. The engine will sound Wierd, so go fairly slowly, so it doesn't.
Or use an air compressor to dry it
29th May 2013, 11:30 AM
The ERG has been blocked with a plate and there is a catch can in place, will check all this. mates who have followed me in have commented on how smokey it is. I suspect a bit of water may be getting past too getting a bit of white smoke. turbo is abit noisy too.
29th May 2013, 01:19 PM
I also have oil visibly leaking from the turbo
29th May 2013, 01:37 PM
Is there oil in the exhaust side of the turbo too?
29th May 2013, 01:46 PM
How much oil do you have in catch can?
I'm Alexander and I'm the happiest owner of GQ Nissan Safari in the whole Central Asia
31st May 2013, 10:47 AM
emptied the catch can, not sure how much oil on exhaust side. can see oil stain on the intake output side of the turbo
