Results 1 to 10 of 14
Thread: Knocking when going over bumps
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Hi all
    I'm experiencing a knocking noise in the gq when going over bumpy terrain at speed(ie normal road driving). But I'm at a loss as to what it is. I've fitted new genuine radius arm bushes, diff end and chassis end, new shocks and springs, new spring seats, new swaybar bushes and links. Have been underneath and nipped every nut and bolt up, suspension wise.
    The noise is worse when it's raining, so I'm starting to lean towards body mounts. Can these make knocking noises when going over bumps? I'd really like to knock this on the head as its abit unnerving.
    Thanks all for viewing, much appreciated.
    Andy
    Did you change the panhard bar bushes. I have seen threads saying that they can split, and knock louder when wet.
    Jan 2013
    Nowra NSW
    5 Post(s)
    Forgot to mention that its got a new tough dog panhard.
    Check your body mounts as well. They lose their integrity and can do what you describe.
    Jan 2013
    Nowra NSW
    5 Post(s)
    Cheers. I did spray the body mounts on the right hand side with some silicon spray and funnily enough, it sounded exactly as it would in the wet. What usually fails with the body mounts? Could they just do with a re torque?
    Legendary happygu's Avatar
    Check for cracks in the inner guards that make knocking noises too.
    I had that on my old GQ after spending three years up north.
    Mic
    Jan 2013
    Nowra NSW
    5 Post(s)
    Cheers mic, I have heard about the inner guards causing issues like this. Someone posted a write up with a fix ages ago, will have to see if I can find it.
    The rubber just gets tired and and then you get the contact you are feeling as they aren't cushioning it anymore. If it is your body mounts you may find if you fit a full set of new ones the body will sit up a little more
  10. The Following User Says Thank You to nissannewby For This Useful Post:
    Bloodyaussie (29th May 2013)
  11. #9
    Beginner 2.8PWR's Avatar
    One of my mate's GQ had a snapped body bolt and made a knocking sound over bumps as you described
    1998 GU Wagon, RD28ETI, Custom Exhaust, Chipped, Go Baby Go Switch, No plans to swap it.
  12. #10
    Hardcore healy's Avatar
    south east melbourne victoria
    Have you checked the swaybar connections that was my issue with the knocking
    IF ITS NOT BROKEN IT MUST BE A PATROL
