Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Scan Gauge.. is it worth it for a non turbo 4.2?
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Hi guys.. with the old q getting on I'm looking at adding a few extra items to assist with keeping an eye on things..
    I have an egt gauge on the way, but was wondering about a scan gauge.. is it worth it for a non turbo 4.2?
    Owner of
    Westy's Accessories
    Pretty sure scan gauge won't work..... Works on a different software thingy
    Don't slap it, tap it!!!!
  4. The Following User Says Thank You to Clunk For This Useful Post:
    BigRAWesty (21st May 2013)
  5. #3
    Answered in your other thread...... Mods, could you merge them please? Ta
  6. The Following User Says Thank You to Clunk For This Useful Post:
    NissanGQ4.2 (21st May 2013)
  7. #4
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Kallen, have started a new thread for your Q
    Answer in short is yes, but really depends on what info your trying to get out of it as the GQ's don't have pull a lot of info out of the standard ECU.
  8. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  9. #5
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Basically want to keep an eye on the workings of it all.. it will soon be a tourer and towing vehicle. So egt is a big one in my eyes.
    I guess first up I need to see if its comparable with the ecu of the 91 Q..
    Owner of
    Westy's Accessories
    22 Post(s)
    Owner of
    Westy's Accessories
    I can't see you needing an EGT for NA unless you are going to put one on every cylinder. Which will differ due to inlet manifold design.
    I would recommend, oil pressure, oil temp and water temp. maybe put in a coolant level sensor. It's an old mechanical donk, A good ear can also tell you a few things
    My 2c
    96 GQ coil/Cab
    08 G6eT
  11. #7
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Yea fair call. Guess I want to be sure.
    But how would the egt's differ from NA to turbo? If your saying one on each outlet wouldn't it be the same turbo'd?
    Owner of
    Westy's Accessories
    22 Post(s)
    Owner of
    Westy's Accessories
    You'll still have different temps with a turbo per pot, but the turbo is also a heat generator. You won't get the same temps NA. Or as quick, heat issues will will be able to be spotted by oil and water temp
    96 GQ coil/Cab
    08 G6eT
  13. #9
    Aug 2010
    17 Post(s)
    yeh I'm pretty sure your plug would be Nissan Consult and not ODBII, I'm pretty sure as Cluck has said it won't work on your year model but you can still use ones like ECU Talk www.ecutalk.com
  14. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  15. #10
    Cheers Todd, couldn't remember Nissan Consult but knew that the OBDII wouldn't work........... there is another thread on here somewhere that talk a bit about this stuff but for the life of me can't find it at the mo. And I could well be wrong but I also thought that ecutalk would only show error codes
