Why can't you fit flexi flares to a GUIV? If you can't fit flexi flares to a GUIV, what are the options when fitting wider wheels?
Still not sure what GU my '06 is.
Cuppa
Because a GUIV has the current shape large moulded flares and it would look like Junk!
Options are up to Neg 6 without trouble
Going by your avatar alone Cuppa you have a Coil cab GUIII DX without any factory flares running split rims.
You could fit flexi flares onto your guards mate but it would look crap if you had factory flares as well.
Originally Posted by Rogue Dung Beetle
The only good thing about an 80 series is..... the front end?? Wrong!!, the Engine?? Wrong!! the Full Time 4WD system?? Wrong!! Its the NissanPatrol.com.au stubby holder fitted over the transfer lever. WARNING: Towballs used for recoveries can, and do kill people and damage property.
Thanks MR,
Coil/leaf DX. No flares at all. You have reassured me. I will have to fit flares of some sort on the front when I get the new rims & wheels (rear will be ok) & the price of factory/fibreglass aftermarket ones is seriously crazy. Flexi's won't look as good but would be far more practical & affordable.
I have seen one pair of factory flares at a relatively reasonable cost however & have made enquiries because the seller commented "DOES NOT EASILY SUIT VEHICLES WITH BULL BARS!!! PLEASE ASK FOR INFO!!!" Not sure if this means they need to be cut or what.
Cuppa
2006 4.2TDi ex-Telstra Remote area Camper. 425w roof mounted solar, 360Ah Aux batts, BCDC1240, Onboard hot & cold pressurised & filtered water, (25 litre hot water calorifier), ARB fridge, ARB freezer, Built in kitchen, heaps of easy access storage, 240v, 3” Genie exhaust + dynotune, 2” lift, 3900kg GVM upgrade, second glovebox, ROH Blaktrak steel wheels, Bridgestone D697's (now Toyo RT's), Redarc gauges/pillarpod, Hema HX-1, Icom 450 CB, dual rear view cameras, Onboard 30amp Victron mains charger, second glovebox, dual seat conversion, TPMS, Boss PX7 onboard air with 9 litre tank, 350w inverter, Steel bullbar, Harrop Eaton diff lock (front), Warn winch, Snorkel, Dual spares , 160 litre water tank, 180 litre fuel in two tanks (approx 1200km range) 2010 Tvan Tanami. (incl another 70 litre water tank) with matching wheels/tyres (& 3rd spare) A Nomadic Life (Blog)
Thanks MR,
Cuppa
Can't imagine what he is talking about??
Maybe he is confused with Brush bars down the sides? Even then you should have no trouble. Flexi flares look pretty good on a DX actually. I think Healy has flexes on his white one? Check his build thread.
There garden edging previous owner done it terrain tamer do a nice flexi set which is what I will be putting on in a few weeks with the garden edging its just the cutting to make it look good is the pain but certainly the cheapest option you can do strength wise
The earlier GU's have wider flares than the later ones and the neg13 16x8's with 33's on them that i tried the other day sat nicely, just on the edge actually but still under.
