19th May 2013, 06:05 PM
Torque converter LS1 Install
Too all the auto Guru's, I installed the torque converter into my 4L60E and got the 2 clunks. Bolted the engine and gearbox together, no problems there!!!!! Although when I went to bolt the torque converter to the flex plate, there was a 5mm space between the two. Question is, Is this normal????
19th May 2013 06:05 PM
19th May 2013, 08:45 PM
GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
KEEP OUR TRACKS LITTER FREE!
The Following User Says Thank You to BearGUST For This Useful Post:
19th May 2013, 09:02 PM
As you tighten the bolts the converter should slide towards the flywheel. If it doesn't you have jammed it somewhere.
The Following User Says Thank You to Alitis007 For This Useful Post:
19th May 2013, 09:42 PM
Yeah it slid together nicely when I tightened up the bolts. Cheers for that. I would hate to destroy the pump after I had just rebuilt it.
20th May 2013, 12:05 AM
Cool no dramas, that would be terrible mate i know i would definitely would have started throwing tools in all directions if i did that lol
