Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 57
Thread: How do i change a gu cv
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Thanks Tony for enlightening me on the hubs.
    I did mean 2 say top job on ur post, but then got carried away with wondering if the hubs were the same or not.
    So Top Job mate, great set of destructions
    Beginner dsm2750's Avatar
    Great work Tony .. Should be put up as a sticky for future reference
  4. The Following User Says Thank You to dsm2750 For This Useful Post:
    jack (26th August 2012)
  5. #13
    330 Post(s)
    Hey Tony great job on the pictorial and write up mate, nice work..
    To add to this though it should be pointed out that "replacing" the CV in this pictorial is assuming that whoever is doing this has a second hand one still connected to the axle and are just doing a swap over.
    If they are buying another CV then they will need to Press off and press on the new one onto the axle. which would be the next step. I wouldn't mind knowing how to do that to to be honest if you can add those pics, otherwise i would take the CV / Axle assembly somewhere for the CV swap..
    Lastly.
    Word of warning to those undertaking this, when refitting the new CV & Axle be very careful to limit the weight placed on the axle seal when installing the axle otherwise it will leak like a sieve. even a new axle seal will leak if treated badly. If doing the long side (the left) take extra care as the longer axle will get heavy installing it. Dont just "slide em in".
    Good luck.
    Well done Tony.
  6. #14
    Thanks MR.
    I don't know about pressing the CV off the axle, if its anything like a front wheel drive CV (I have not tried it with a 4WD front CV) then it will be a case of securely holding the axle shaft in a vice, and using a brass drift and a hammer to knock the CV off the axle. On front wheel drives there is a spring clip on the end of the axle spline that locates in a recess in the CV joint spline, I think 4WD CV's would be the same.
    You are correct about being very careful with the axle seals. It's good practice to replace the inner axle seals when ever you remove a CV, unless you like to play hard and break CV's on a regular basis! The inner axle seal can be seen still in the housing in the photo below. I will go into more detail regarding replacing these seals when I get new seals to install.
    Tony
  7. The Following User Says Thank You to YNOT For This Useful Post:
    mudnut (31st October 2012)
  8. #15
    Mar 2011
    Very informative, thanks guys
  9. #16
    Apr 2011
    Tony,
    I'm looking at replacing my rear rotors on a 98 4.5ltr GU. Do I basically do the steps up to step 7 and the just take the rotor apart. Any help would be appreciated. Have just downloaded the Factory Manual and will have a read tomorrow.
    TOOR
  10. #17
    Quote Originally Posted by Ruby View Post
    Tony,
    TOOR
    No, rear rotors are much easier.
    Remove the wheels (obviously!) remove the brake calliper bracket with calliper still attached then remove the rotor. Easy.
    Tony
  11. #18
    Apr 2011
    Thanks Tony,
    I'll ring around and get some prices for Rotors tomorrow
  12. #19
    Apr 2011
    Vic, NT, Tas - On the move with work
    Thanks Tony, been getting a lot of good stuff from your write ups.
  13. The Following User Says Thank You to Burden For This Useful Post:
    YNOT (5th April 2011)
  14. #20
    Glad I could help you mate.
    Tony
