19th May 2013, 12:35 AM
#11
Battery is not flat. Got 12v. Checked that. Terminals are good. I should of been more specific as to say it does crank over. Just doesn't start.
19th May 2013 12:35 AM
19th May 2013, 01:12 AM
#12
Legendary
Alitis007
You need a process of elimination so start with spark and injector pulse then check the fuel pressure, power at the lock offs/solenoids,fuses,relays and wires around the battery. Also check that the petrol / gas toggle switch is working correctly but you will know this if there is power to the lock offs. Lastly you can check the motor for compression but one of the above will not be present and point you in the right direction.
hershal
Just follow my original post then, i was just eliminating a starter motor coz i thought you said it didn't but all good!
19th May 2013, 11:14 AM
#13
Cheers mate. Going to tackle it a bit this morning. Lets hope it's an easy fix
19th May 2013, 08:05 PM
#14
Alright so I spent a few hours this afternoon trying to problem solve this issue with my car.
I checked the battery - Its fine, removed terminals cleaned put back on tightened, Still fine. Even tried to boost the battery by a jump from my other car, Still nothing - Pretty Much saying its not a battery issue.
Checked the Air Intake system - Pulled it all apart from the Filter to the engine. Even pulled the part where the gas goes in. Don't know much about it but it "seems" good and nothing visually wrong. No blocks or anything like that, no moisture etc.
Pulled Spark Plugs and checked, all look in good condition, but I will probably replace these anyways just to be safe, why not. Leads look all good too. Was getting a spark out of every plug, every lead.
Distributer, Pulled this apart, well removed the cap and cranked the engine, seems to me that its not spinning that fast. Again I am far from an expert but should this thing spin fast or slow? I have uploaded a video to show you what I mean. Please tell me this is the issue
Didn't check fuel system yet though, Was working in my garage and didn't want to make a mess But tomorrow ill put down some sheets and trays and pull the filters and check the lines. Can someone also tell me if the fuel pump is mechanical or Electric?
again thanks guys for all you input on this
https://dl.dropboxusercontent.com/u/...9/IMG_2578.MOV
19th May 2013, 08:14 PM
#15
Patrol Freak
Seems to be spinning fine hershal.
Is the car fitted with an alarm or engine immobiliser?
If you can get ahold of someone with a noid light to chuck on the injectors, this will indicate if they are pulsing. If you have a pressure guage, chuck it inline on the fuel line after the fuel filter and before the fuel rail. Should get 40psi. If not, this could indicate lots of problems, bad fuel regulator, bad pump, blocked lines, no fuel, who knows...
19th May 2013, 08:16 PM
#16
Hardcore
Your rotor button looks fine, turning ok.
Have a look inside the top of the dizzy cap and see if the little carbon tip is still there and making contact with the top of the rotor button,it is spring loaded.
Cheers, the ferret.
19th May 2013, 08:30 PM
#17
Parksy
Car is fitted with an immobiliser, when its on it wont even crank once its off it does crank.
Don't know any one with one of those lights, might be a last case scenario. Ill try and find an inline gauge, im sure you could pick one up from a car place etc, hoping its ok, like I was saying in previous post I was low on fuel when I was off to fill up. Since then I have put more fuel in, hoping there isn't some kind of block or anything,
19th May 2013, 08:31 PM
#18
the ferret
Cheers, the ferret.
Dizzy cap looks all good I pulled it off looks pretty mujch brand new, no build up or anything. When the RAC guy came out to tow me home he also said it was fine, he too couldn't work out the issue with this thing
19th May 2013, 08:42 PM
#19
Legendary
Did you check if the fuel lock offs where getting power ?? 1 for petrol and 1 for gas
19th May 2013, 08:47 PM
#20
Alitis007
to be honest I don't know what they are, probably a stupid answer to some but yeah I was gonna ask later if I didn't get it going with something else
