Results 11 to 20 of 21
Thread: Inspection Camera Aldi and Autobarn?
    Jan 2015
    tip: something that goes well with an inspection camera, if you haven't already got it, is a flexible magnetic pick-up tool. you can see the screw you want back with the camera, and get it with the pick-up tool. i've had a nut decide to live inside a chassis rail and it would've been a lot worse without one to try and fish it out
  2. The Following User Says Thank You to pat in a troll For This Useful Post:
    mudnut (27th June 2015)
    Good tip, mate.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    pat in a troll (27th June 2015)
  6. #13
    Hardcore
    central coast nsw
    Off topic but another thing for getting that hard to reach item,
    compressed air, providing it can fall out and not become trapped farther back.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  7. The Following User Says Thank You to Robo For This Useful Post:
    mudnut (28th June 2015)
  8. #14
    Another good tip.
    I have to get a silver
    ring out of the heater.
  9. #15
    bummer that silver it not magnetic, are you 110% sure its gone past the ducting and into the heater.
    turn heater on and see if you can hear it??
    I'm not convinced it went down the duct, not pulling your leg is he lol
  10. #16
    Nah, I saw it fall down. As
    he went to put it on the dash
    the Trol hit a bump and threw
    off his aim. I tried scraping
    every mm of the duct with a
    bit of coat hanger. There is no
    catchment so the ring has rolled
    down into the heater module.
    I also wish to inspect the inside
    of the chassis and body panels.
  11. The Following User Says Thank You to mudnut For This Useful Post:
    threedogs (28th June 2015)
  12. #17
    Jan 2015
    That sounds unfortunate. the retail stores around here have pretty expensive cameras, but you've got to be careful with the dirt cheap china stuff because it won't last as long (although if it's not needed everyday it might last a while). a good secondhand one would be good
  13. The Following User Says Thank You to pat in a troll For This Useful Post:
  14. #18
    175 Post(s)
    I got the Aldi one few weeks ago when they had one. Works great so far, came with a bunch of attachments...
  15. The Following User Says Thank You to Hodge For This Useful Post:
  16. #19
    A trip to Warnambool
    SCA is on the cards.
  17. #20
    Picked up a cheap usb style camera.
    It works great.
    Found the ring, but the hook
    from the camera came off and
    is stuck as well. I'm off to post
    in the angry thread.
