16th May 2013, 10:11 AM
#11
No need to double clutch. Your only removing drive from one shaft not changing ratios.
16th May 2013 10:11 AM
16th May 2013, 10:46 AM
#12
Yea I posted a while back I think..
No need to clutch at all Benny, just foot off accelerator. Great if you need a bit more speed before a bog hole..
16th May 2013, 12:05 PM
#13
No: 10,
Whats the actual benefit of manually locking the front hubs other than the speed you can change from H2 to H4, can you leave them manually locked all the time.
16th May 2013, 03:14 PM
#14
Tonks
No: 10,
Yes you can leave them locked all the time, it just causes the front drive shaft to windmill. It causes no damage, and could be advantageous occasionally since it will allow the diff oil to splash about.
It's possible that the increased load of the rotating axle and shaft will increase your fuel consumption slightly.
Steve
2011 Patrol Safari 4.8 (Fitek)
16th May 2013, 04:26 PM
#15
Perfectly fine to leave front hubs locked. As mentioned it keeps oils circulating.
But yes you increase the fuel consumption and steering is a little heavier.
My q had them locked for the first 100 thou..
16th May 2013, 04:53 PM
#16
Cheers guys i think i will lock them in for a while, it can't hurt,
Thx
Tonks
16th May 2013, 05:40 PM
#17
I drive with the front hubs locked at least once a month, to keep all the seals lubed. One quirk the Old Trol has is the steering wheel goes slightly off centre when in 4wd.
16th May 2013, 05:56 PM
#18
In winter I keep my front hubs locked in as I live in a constant of snow and ice from June to October. Its saved me many times being able to smack her in to 4h when its going peer shaped sometimes halfway through a corner sometimes on a straight sometimes on a hill
16th May 2013, 08:28 PM
#19
Patrol Freak
Granny shifting not double clutching like you should!
16th May 2013, 08:34 PM
#20
Smart like tractor
trekster
I better watch out my nitrous, might blow the welds on the intake manifold hhahahahahaha what a load of crap.
96 GQ coil/Cab
08 G6eT
