15th May 2013, 10:14 PM
Help finding reversing light wires
Please advise if you can help me locate the reversing light wires under the dash of my 2005 Nissan Auto Diesel. I have fitted the camera to my caravan but haven't got a clue as to where the reversing light wire is.
Thanks Pete
Reason: Edited Title
15th May 2013 10:14 PM
15th May 2013, 10:25 PM
Pull the tail light out and see which wire runs to the globe.. but not sure if it would be under the dash. Possibly behind fuse box
15th May 2013, 11:07 PM
Patrol Freak
One would think there would be something around the t-shifter? Move it into reverse and the wire picks it and powers the reverse light?
The Following User Says Thank You to trekster For This Useful Post:
BigRAWesty (16th May 2013)
15th May 2013, 11:27 PM
Legendary
i think there is a wireing loom (connector) under front drivers seat of run a wire from the back
or just have it live all the time so when driving you can see behind caravan
2007 GU 6 /ST-L / MYO8 / DIESEL/AUTO /MOONSTONE /pro vent 200
OH LEATHER IS NICE
15th May 2013, 11:49 PM
Legendary
my third 256
Depending on the individual, having it live all the time can drive you crazy!!!
1999 GU 4500 dual fuel
Il dado è tratto
16th May 2013, 11:47 AM
Thanks for your advise.
Peter C
16th May 2013, 04:25 PM
My take on this is:
You have wired up a reverse camera to your caravan, and need the reverse light to send a signal to your camera to turn on?
Are you hoping to find it close to the screen (in cab)?
Or at the back of the vehicle? (in a trailer plug there is provision for such a signal. Used in one instance to activate a solenoid to disable the hydraulic brakes.)
I am unsure if this wire is connected in a patrol.
16th May 2013, 04:38 PM
Should be one coming off Auto or gearbox ,Loom may be under centre console,
Not 100% sure have you tried searching, must have been done heaps of times.
19th May 2013, 02:24 PM
Thanks again Three dogs. reversing power found in channel along side passengers seat,
Monitor power taken from auxiliary connection under split covers on steering wheel. all sorted and working.
ps. Have you heard of the sub-tank being used without the under dash press button being operated ?
A bit of a nuisance on long trips. Nissan can't find fault, nor can I as it only happens occasionally.
Not real flash when you expect to have a full sub-tank and it's half empty !!
Thanks again mate,
Peter C
19th May 2013, 02:29 PM
Advanced
Peter, your sub tank question may be simply that each time you start up your Patrol the pump deposits a small amount of fuel from the sub to the main (I seem to remember this is spoken about somewhere in this forum). I can't recall the exact reason but I think it has something to do with not allowing the fuel to sit in the tank for ages and become stale. It is surprising how each little squirt will eventually drain your sub.
