20th June 2013, 08:00 PM
Hard wire it mate...! you must have a constant 12v supply behind the dash you can tap into. If you remove the shroud under the steering wheel you may find a spare factory plug... it will have constant 12v. Depends on what year your GQ is. Mine is 97 ST and it has one.
20th June 2013 08:00 PM
20th June 2013, 08:40 PM
Travelling Podologist
Lancec2626
Hi Lance,
it's all done now thanks. It's an ex telstra GU & I did hard wire it, direct to the battery with an inline fuse holder on top of the battery. in your other post about the switch, thanks again, I found a taped up Telstra cable coiled up behind the dash with a 12v supply (positive & negative) independent of the ignition so used that.
Cuppa
21st June 2013, 01:45 PM
AWESOME, wired for sound,,,,,,,,,,,,,,,,,,,,,,,
The BigFella
500,000ks and still counting!
21st June 2013, 02:17 PM
Have you had the SWR checked on the antenna? I used to check it on AM radios, because it was critical. I installed my Uniden FM without doing it, but since then, I have been advised to do it, to get maximum output and range.
22nd June 2013, 01:21 PM
mudnut
That may be something I'll have to wait until someone who knows what to do visits!
29th June 2013, 11:09 AM
just hook it up off radio accessorys circuit...
