Page 20 of 20 FirstFirst ... 10181920
Results 191 to 194 of 194
Thread: GU Second glove box mod DIY!!!
  1. #191
    May 2022
    North East Vic
    Yeah hard to believe I did this all that time ago. Glad I took the time to post it up, seems to have helped a few out which is what we always want to do. Mine is still functioning perfectly too by the way.
    Everytime I go camping in mine and use the back of the car, I always think more can be done to utilise the two barn doors, for storage or something. The mind never stops ticking...
    Hey mate, try this out, I copied his idea and works a bloody treat
    https://youtu.be/WvpDZph3sUg
  2. The Following 2 Users Say Thank You to Levante14 For This Useful Post:
    MB (22nd May 2022), mudski (23rd May 2022)
    Quote Originally Posted by Levante14 View Post
    That mod looks excellent, but...
    It will significantly reduce the strength of the door. A previous owner of my Patrol cut a large hole in the inner sheetmetal of the rear D/S door to fit a speaker. The door has started to crack in a few places. On bumpy roads the door creeps open just enough to start an annoying squeak. I would suggest fabricating a system of brackets to brace the structure you have cut into.
  5. The Following User Says Thank You to mudnut For This Useful Post:
  6. #193
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I'm guessing this is the tell tale sign that I have an airbag and can't do the mod DSC_5162.jpg
    .......from under the great down under.
    Hello from Under Down Under!
  7. #194
    465 Post(s)
    Unless you disconnect and remove the air bag, you cannot unfortunately.
