Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: DP Chip # DP34 Installaition and Tuning guide
    460 Post(s)
    To suit GU Patrol with the 3Ltr Direct Injection motor. Please check if this is the right instructions, DP#34, for your chip prior to using.
    Tuning1.pdf
    tuning2.pdf
    coverback.pdf
    cover.pdf
    wiring diagram.pdf This wiring diagram if for a 2001 Y61. ST model with manual trans and no dual zone air or ABS. As there will be a difference.
    If theres a better way to put these pdf's on here, let me know...
  2. The Following 3 Users Say Thank You to mudski For This Useful Post:
    AB (4th March 2015), NissanGQ4.2 (4th March 2015), Paule (4th March 2015)
    Ballarat, Vic
    173 Post(s)
    Hi Mudski, one way to put them in your post is like this.
    First convert or save the files as .jpg rather than .pdf.
    Second use the ‘insert image’ function
    this brings up a box allowing you to select an image off the ’net or off your computer. The select off your computer doesn’t work for me, but if you click ‘Basic uploader’ that works. I’m not sure how it’s possible to have the image embedded in the post without the additional ’thumbnail attachment’ showing too.
    Cuppa
    Ballarat, Vic
    173 Post(s)
    An alternative is to upload the .jpg to a free photo hosting site like Flickr & then link to it in your post like this.
    Good timing Mudski as Dinger is after a wiring diagram for the DP chip, well done
    460 Post(s)
    Yeah I thought of that but I wanted to do it so they could simply download the pdf and print if off.
    Thanks.
    Expert Paule's Avatar
    Jan 2014
    Sandhurst
    Mark you are a champion mate. I knew you had posted this up before because i had seen it about 9 mnths ago. i was up until all hrs searching the forum until I found it. So thank you very much for finding the information again, and posting it up here. P.S I got your old thread back up and it was very easy to print off in one hit. Thanks again
  9. The Following User Says Thank You to Paule For This Useful Post:
    mudski (4th March 2015)
  10. #7
    460 Post(s)
    No worries Paul. I thought I had posted it before but I could find it too for some reason.....
  11. #8
    Ballarat, Vic
    173 Post(s)
    Thanks.
    No worries, I thought you just wanted to embed a pdf into your post. Doing it as you did in your OP achieves what you wanted.
  12. The Following User Says Thank You to Cuppa For This Useful Post:
  13. #9
    Jan 2014
    Sandhurst
    Ok so I've just had a quick look at how to install this chip and I'm wondering how you guys went about connecting it to the pump. I can only see about 10mm of cable where it's meant to connect too. Did you just solder it on there or is there some special adaptor you used? Thanks
  14. #10
    460 Post(s)
    Yeah those two wires on the pump are a real pain to get to. I just used scotch locks.
  15. The Following User Says Thank You to mudski For This Useful Post:
    Paule (10th March 2015)
