Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: roof consol help please
    174 Post(s)
    I'm gonna beg to differ with Mudrunner a bit.
    Firstly though let me say that I've never had a 4wd with drawers in it, whether in a bog hole or not. I have however removed someone's previous effort at fitting out our bus in MDF & replaced it all with pine framing & aluminiunm angle framing, clad in 3mm, 5mm & 7mm ply. I estimate that I saved half a tonne of weight doing so, it is very heavy stuff.
    It is also true that painting (or varnishing) MDF will seal it, but make sure you do a damn good job, 'cos if moisture gets into it swells like a tampon in a glass of beer! lol.
    I'd also agree that 6mm MDF is a reasonable choice for an overhead console (although 3mm ply on a riveted aluminium frame would be lighter (but more dificult to construct).
    What I would disagree with is that MDF is ok for the drawers. Not only are drawers more vulnerable to getting wet, but chances are you would need to use 19mm MDF & that is going to be way heavier than the Plywood alternative. Mudrunner's suggestion for 12m & 15mm ply is a far better alternative to MDF (& safer too. most places selling it these days won't cut sheets for you because of OH & S - it gives off a very fine & toxic dust when cut with power tools).
    On the topic of overhead consoles in general, I'd be interested in what anyone who has one fitted actually thinks of theirs. I have this gut feeling that they are one of those things that look like a good idea but in practice are less so?
    Cuppa
    43 Post(s)
    I'm fitting a threw the center style for a few reasons..
    1- I'm out of din spots.. I have a pull out cup holder which sits into a single din spot, so I will be using the in dash one above the uhf..
    2- it gives us a little more storage for things like maps and mags.
    3- the reason for going center over across the front style is my height.. I'm 6'1 so if I was to lower the roof line it would impede line of sight, and also add a nasty hazard.
    4- I intend on fitting a flip down DVD player for the rear seats (kids).. currently have a 7" portable DVD player but as no. 2 gets older she'll want to watch aswell..
    So if I can source a split single din DVD player with external screen option this will be fitted into roof console.
    So yea, mine will be functional. And sexy..
    Owner of
    Westy's Accessories
    Patrol Guru
    Apr 2011
    Melton
    I had a roof console across the front of my MK - it was great for mounting the cb - first aid kit etc
    I was always scared that if I had a stack - I might have split my head on it. Plus I had higher seats that result in some vision retriction
    I have looked at the consoles that run long ways - mirror to light. I like these and considering going this may
    The mk was aliu covered in carpet (fitted to the truck when I picked it up. The sun shades where mounted to the bottom of the roof console.
