Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Routing cables into cab
    Advanced Country_GU's Avatar
    Hey guys I'm in the process of mounting a UHF antenna and a mobile antenna on my bullbar, but there's only one problem. Where in gods name can you route the coax to go into the cab, I can't find any free grommets or even easy ones to access, anyone give me any tips on getting cables into the cab?
    Cheers in advance
    Maroon 2000 GU II ST
    04 ZD30 heart transplant half bulletproofed!
    Winning!
    WA Wheatbelt
    23 Post(s)
    On the firewall - under the dash, about where the passenger floor well is, there should be a rubber thingie that leads into the cab.
    That's where all my cords go through. Hope my directions make sense? lol
    Rossco
    330 Post(s)
    Quote Originally Posted by DX grunt View Post
    Rossco
    X2.. It is quite big and i have quite a few cables going through it. about 50mm to 70mm round. Under the Aircon hoses mate.
    X 3 that thingie would be like a big rubber Gland if thats the term , it accommodates a heap of wire .
    you may need to put a small hole with a knife carefully first.
  6. #5
    330 Post(s)
    Yep size of a Sink Plug mate.
  7. #6
    Yeah I saw that, mine has some strange plastic crap with like wool behind it, is that standard? It's an st wagon
    Winning!
  8. #7
    Probably firewall insulation ?
  9. #8
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    More than likely TD, should be 1 on each side to use
    Never underestimate the power of the Tap.
    www.swat4x4.com
  10. #9
    Power of the tap?
    Winning!
  11. #10
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    Quote Originally Posted by Country_GU View Post
    Power of the tap?
    Tapatalk Sig. Like mine below...
    Um, mine didn't have one on passenger side.. but there is one behind the 1/4 pannel, just below the glove box.. bit of a pain to get to without removing the 1/4 pannel but doable
    Owner of
    Westy's Accessories
