12th May 2013, 10:08 AM
#31
The 747
That's okay I have a spare.
12th May 2013 10:08 AM
12th May 2013, 02:26 PM
#32
I think you might have more then just a problem with your glow plugs.
Possibly a fuel supply problem......maybe a faulty solenoid on the injector pump???
Get the glow plugs working first and see how it starts.
The Following User Says Thank You to Yendor For This Useful Post:
Bloodyaussie (12th May 2013)
12th May 2013, 05:17 PM
#33
The 747
Thing is though I started it with aerostart once and it still runs beautifully. Should I put some wire from the battery to the glow relay for a few seconds and try that?
If you're happy and you know it tap a post!
12th May 2013, 06:07 PM
#34
Winnie
No......not if you haven't got the insulators fitted to the glow plugs.
If you do have the insulators fitted you can get some wire and temporary touch it on the positive battery post and the glow plug rail.....carefully, this wire will get hot.
Then try and start it.
12th May 2013, 06:11 PM
#35
The 747
Yep I'll do that when I get the insulators on the plugs. Would you know if you can buy those seperately or will I have to buy 2 new plugs?
12th May 2013, 06:17 PM
#36
Don't know sorry. You can use anything as long as it's not conductive such as a fibre washer.
12th May 2013, 06:47 PM
#37
Dont confuse him Rodney..... this is a guy that thinks there is only one type of beer???
12th May 2013, 06:51 PM
#38
The 747
There's only one GOOD type of beer.
Thanks Rodney I'll make something if I have to.
The Following User Says Thank You to Winnie For This Useful Post:
threedogs (16th May 2013)
12th May 2013, 06:59 PM
#39
It will be better if you can get the original ones if possible. See how you go.
16th May 2013, 03:30 PM
#40
The 747
Bursons had the insulators but dear for what they are.... 6 bucks! Better than buying new plugs I guess.
Got a fusible link coming from Patrolapart, could not find them anywhere else from local wreckers or even nissan themselves.
