Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 89
Thread: Changing glow plugs... NEK MINNET
  1. #21
    Sounds like a dodgy connection somewhere. When everything was working did you check you were getting full battery voltage at the rail befor you blew the fuse.
    Nah I don't have a multimeter just a test light so all I can say is it was getting at least 6V. Just checked my other patrol and it has a different size fuse there for the rad fan.
    If you're happy and you know it tap a post!
    North brissy
    Get one. They are cheap.
  4. #23
    I am waiting for the one I want to go on dead stock list at work so it will be cheap hahaha
  5. #24
    The glow fuse and other connections are full of a paste type stuff?
    Last weekend my battery died, jump started and gave it a good drive. 5 minutes later it was flat, I thought battery was dead so swapped it and was fine after that. Went to drive it the week after and plugs were dead.
  6. #25
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Yeah that's how I had it? Didn't work. Before I touched anything if I glowed the plugs about 5 times it would start, not now. That's when I took the plastic rings off and blew the fuse.
    The glow light still comes on in the dash and the timer still works too.
    Check the fuses inside now. There should be one marked IP. Check all of then.......turn the ignition on and make sure you have power on both sides of the fuses.
  7. #26
    Hey Rodney, can confirm that I have power on both sides of every fuse inside.
  8. #27
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    You will need to check you are getting power to the solenoid at the the injector pump....with ignition on.
    If you don't have an alarm or shut down timer fitted you should be getting power there but you will need to check.
    Have you refitted the insulators and replaced the glow plug fuse?
    How's your battery now? is it still turning the engine over fast enough while cranking?
  9. #28
    I am missing two of the insulators now so will need to get some on Monday... same deal with the fuse I will have to get that on Monday too.
  10. #29
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Stick to petrol?
    .......very helpful i know
    Hello from Under Down Under!
  11. #30
    Thomastown, Melbourne
    6 Post(s)
    So what you are saying Winnie is your car is sitting there like a big huge brick......???
    HHmmm chook pen, maybe a home for cats...... bed sit for uni student maybe, after all it has a fridge!!!!
