7th May 2013, 10:28 PM
160k service GU 3 lt turbo diesel
hi all, just been quoted $1225 for my 160k service on my GU from our local dealer. nearly fell over, so i am wondering what do you get for $1225 and should i just go for the minor service.
7th May 2013 10:28 PM
8th May 2013, 12:13 PM
Ever thought of doing it yourself? Get the Service Manual and go through each item. I haven't got one in front of me but I would be surprised if there are more than a handful of items for which you will need a specialist.
Without knowing your mechanical ability and access to tools its unfair to be too pushy I suppose but this Forum would have the answer for just about everything you need to know. I didn't even know what a NADS was before I searched this site. Now fully installed thanks to the info found here.
And caving in to the stealership's outrageous bid for your work just encourages them.
8th May 2013, 11:12 PM
i have good mechanical knowledge and a pretty well equipped garage, however this is my first patrol and just wanted to check if this was something people in the know would recommend i do but looks like i should just go ahead and do it myself, thanks for the reply
9th May 2013, 05:27 PM
without looking at my service log book, I don't know whether it is a major one or not. but in saying this if it was a major one I would say they would do the usual like, engine and oil filter change, fuel filter change, air cleaner replacement, diffs, transfer case, transmission fluid changes, radiator coolant, grease tail shafts, repack wheel bearings, inspect brakes or replace brake pads, brake fluid change, power steering fluid change. these are the basic changes I can think of for a major. and there is no doubt more. if you are mechanically minded do it yourself you will save money and will get to know your troll. I do my services and I'm a female.
3lt GU 111 Wagon 2 inch lift,3in Taipan exhaust, cross country intercooler,catch can,EGR blocked, dawes and needle valve,Pyro/boost gauge ARB lockers,steinbaurer chip, long range tank, s/s water tank, draws, warn winch, and other stuff.
10th May 2013, 12:49 AM
cool . i am convinced that his is definitely not worth the dollars they are asking, time to get the spanners out
