Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Steel bushman fry pan
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by roofy View Post
    don't use a good one though just in case it doesn't work
    haven't heard that one either
  2. The Following User Says Thank You to Sir Roofy For This Useful Post:
    TheLocksmith (21st June 2013)
    Maybe Utube will show a Chef seasoning a new spun steel Wok
    Cant hurt any fry pan except maybe alloy, but works on spun steel and cast iron.
    All my pans are seasoned this way then just clean as per normal,[No Soap]
  5. The Following User Says Thank You to threedogs For This Useful Post:
  6. #13
    Jun 2013
    Originally Posted by threedogs
    Buy 2kg of salt tip into frypan and leave on heat, you'll have a non stick spun steel pan straight away
    Is this a once off thing or every time you go camping?
    Good little trick tho
  7. #14
    NT
    Does it affect the food taste?
  8. #15
    43 Post(s)
    Wrong thread
    Owner of
    Westy's Accessories
