Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: WANTED: standard Nissan 16" steel rims for GU
    Ballarat, Vic
    174 Post(s)
    I would like to replace my split rim/tubed rims with tubeless. I'll need 6 all up. Am watching eBay for some not too far away at a reasonable price, but if you have some gathering dust let me know. I'm in Gippsland, Vic.
    Cuppa
    A Nomadic Life (Blog)
    For some reason Patrol rims are expensive as anything, Are you after OE steel rims 16x8 .
    As a set of mags may be cheaper but no good for your intended use,
    Have you priced a set of sunnies.? If you know size and offset I'll make a few calls
    and see what prices are available, thinking black King rims
    Ballarat, Vic
    174 Post(s)
    I'm not sure that the OE rims are 16x8? The is size I want are whatever the OE rims are. Have decided to stick with the 'cheesecutters' as I believe them to be better for carrying the load I have, & I'm not intending to play in the mud. This size was Telstra's choice, & my intended usage is similar. However I would like o go tubeless for easier puncture repair & the ability to lower the pressures a bit more that with tubed.
    Cuppa
    Thomastown, Melbourne
    6 Post(s)
    I am looking into some ROH rims for you but will probably only be able to get black??
    Sorry for slackness in reply.... my brain is spinning around move out of my way............ yeah I know??
  6. #5
    Think you'll find the DX came out with the 16x6 rims from nissan not Telstra.
    You might find you have better load carrying capacity with 16x8, in LT conctruction.
    Having said that you can get up to 10 ply in 16x6 but few options on pattern, IMO I'd be going
    16x8 which everyman and his dog use with 285s ,100% to find a carcass if the pickings get slim
    Split rims old school but open to debate ,plus dangerous if not paying attention
  7. #6
    Ballarat, Vic
    174 Post(s)
    PM sent BA.
    TD, my point was that Telstra used the 16x6 split rims, & that their usage, predominantly on outback roads carrying heavy loads is similar to what I intend to do. I'm sure that if they had considered going to wider rims/tyres was beneficial they would have done so.
    I was told last night that I will get better load carrying capacity in tyres to fit the 16x6 than for the 16x8. Eg. 7.50x16’s as well as the 235/85 I currently have. Whatever tyres I get will be an AT type for touring, most likely in a LT construction. I'm running almost 70psi in the rears at the moment. Remember I am close to 4 tonnes fully loaded.
    Cuppa
  8. #7
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I think TDs point was that if something happens in the outback and you need another tyre or rim then the 8" wide ones are more commonly used and therefore easier to get hold of in remote areas. I can also see your logic in sticking with the dimensions Telstra decided to use (but they did also choose split rims)Another thing though: you might not go out looking for mud but it may end up being right there between you and your way out.
    In any case, going tubeless and getting rid of the split rims is a good idea.
    FanTapstic!
    Hello from Under Down Under!
  9. The Following User Says Thank You to taslucas For This Useful Post:
    threedogs (9th May 2013)
  10. #8
    As Lucas says All I was saying nearly everyone uses 16" rims so in the event you may need a carcass it'll be easy to pick one up. Having lived and worked in remote Northern territory,
    we never threw away any 16" carcass, we patched and salvaged everything. Everything has/had a use. Gee miss that lifestyle.
    Split rims are a heavier rolling mass as well, so more pressure on your brakes, 70psi seems way too high but happy to be proven wrong.
    Only say that as ,as soon as you start travelling the pressure will go up even more, You're not allowing tyres to absorb any bumps
    must be like driving a bobcat
  11. #9
    Ballarat, Vic
    174 Post(s)
    It's the pressure recommended by our local Tyrepower after they saw how much the sidewalls were ballooning out. Actually I'm running slightly less (68psi) which transformed he handling. 40psi in the front.
    I hear what you are saying about availability in remote areas, trouble is I'm being given conflicting advice. Other folk (off forum) have said the same about the availability of 7.50 x16 as you have said about 16x8’s.
    Have also been told that fuel economy will be better with the narrower tyres.
    It'd be so much easier if everyone agreed!
    Cuppa
    Ps. Can anyone tell me what 16x8 LT tyres (ie with sufficient load carrying capacity) are available with an AT tread pattern?
  12. #10
    Enjoying the trips macca's Avatar
    Oct 2010
    Old Bar, NSW
    13 Post(s)
    Cuppa if you do change to a 16 x 8 be aware these utes like yours & mine with the stock rim (+13mm) & 265's have the rear tyre touch the chassis when articulating at extreme of that travel.
    When I put 285's on I got hold of some ROH BlakTrak for $103.00 each at -10mm offset. They have never touched the chassis rail since.
    Mine is the wide wheel model with OEM flares so you may need to head that way as well.
    Bloody hard to work all of this out, good luck old mate.
    Macca
  13. The Following User Says Thank You to macca For This Useful Post:
    threedogs (10th May 2013)
