Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Portable GME TX3100 80 Channel UFH
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    I pick up one yesterday from a local shop was 20 bucks more than eBay but I thought what the hell good little unit the aerial is good for 2 km range apparently and if you want to later it can be hard wired in and a bigger aerial attached. I am pretty happy with it all round
    Just tap it in just tappy tappy tappy
    Sep 2012
    Mount Gambier, SA
    43 Post(s)
    G'day Westy,
    Close enough... minor thing tho, Channels 41 thru 80 are interlaced into the 'old' 1 thru 40. That means that channels 1 thru 40 are the same on both an old 40 set or a new 80 set. The order by frequency is essentially 1, 41, 2, 42, 3, 43 etc but as the band is 'channelised' the freq's allocated to the channels do not need to be in any order just the same for everyone.
    The emergency freq's work fine with either channel plan as there will be a significant period for the emergency repeaters to be upgraded before the interlaced freq's of 44 and 45 either side of the existing channel 5 are released for repeater licence use.
    Bottom line is essentially that the difference between 40 and 80 sets when operating on channels 1 thru 40 is bugger all other than maybe the need to up the volume a tad
    Sweet as. Good to get some clear data on it.. tbh I haven't read much about it, just talked to others about it.
    Owner of
    Westy's Accessories
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by 93patrol View Post
    Why does it need to be hard wired? cant you just run a bigger aerial on your main vehicle and just use the small aerial when swapping between vehicles
  5. #14
    Dec 2012
    Bunbury
    I believe you can but you couldn't go too big because of the magnet but you could get a mounted aerial and just leave there
